Who uses the Prop Clip?
Do you use a Prop Clip and if so, how do you like it?
I bought one thinking I'd like to see it and potentially try it out. I make a fairly low volume product, so I'm hoping it will work for programming my assembled PCBAs. Is this a good solution or is there a better way?
Andrew Williams
WBA Consulting
PowerTwig Dual Output Power Supply Module
My Prop projects: Reverse Geo-Cache Box, Custom Metronome, Micro Plunge Logger
www.fd.com.my
www.mercedes.com.my
Propeller Forums RSS Feed!
Gadget Gangster - Share your Electronic Projects
Leon Heller
Amateur radio callsign: G1HSM
I don't want to solder a header onto my board. I·currently have problems with unreliable connections using a header and the sx-key and sx-blitz, both on my product and on the sx demo board I got from Parallax. I am considering either a bed-of-nails programming fixture or something like the prop-clip. I may design a few options into the PCB so I can try them out and use the most reliable version. What do you have to do to adjust the spring tension? How often do you use your prop clip and do you have any problems with it?
I like to PropPlug better. Many people have had problems with the header breaking off. As soon as I heard that, I put a small piece of heat shrink tube around the female header to produce some physical attachment to the board. Wish I could take a picture, but my 8 year old digital camera just died. Yeah! I needed a reason to get a new one [noparse]:)[/noparse]
Jim
Customers have spoken a long time ago. But we're still holding bags and bags of molded pieces. . . .Chip wanted to hang on to them "just in case".
Parallax Inc.
Follow me at http://twitter.com/ParallaxKen for some insider news.
Parallax, thank you for lower the price on the prop plug/clip.
/michael
@Michael O'Brien, Glad you like it! We'll have it around for years to come. Let's replace your Prop Plugs, okay? Contact me off-line and we'll work it out. No sense in having dead hardware laying around if you need it to be working.
Parallax Inc.
But as Michael indicates, the Clip works best with a very thin and flexible USB cable.
The pogo pins are much more sturdy that I ever thought they'd be. They've held up very well despite being clipped to all sorts of rough, blobby, and dimpled surfaces.
Ken, does this mean we can expect further discounts on the Prop Clip? Or perhaps the Deal of the Day? Hope so!
"Let's not bicker and argue about who killed who."
Actually there are many connectors that use spring loaded contacts any of them could be easily modified to make something that is pressed against a PCB in a jig for programming.
Graham
