voltage level translation
Hi Guys,
a little bit off topic.... but I am using a BS2p40!
I need to translate the output voltage from a stamp pin (5V) to 3.3v providing a maximum current of 10mA.· What would be the easiest way of doing it?· I have been looking at using an translation IC but it seems overkill for what I need.
thanks
Jon
thanks
Jon
I've read that sticky thanks. The application I am working on will interface my machine with a BS2p40 to a large Xerox production printer which specifies it needs a absolute maximum of 4V @ 10ma to operate it's internal opto isolators.
Would putting 2 diodes in series acheive the same result - each diode dropping about 0.7V?
At the moment I only have a single 5V supply, so if I can avoid adding a 2nd one for 3.3V that would be good!
thanks
Jon
Wait a minute -- opto-isolator unit?· It's possible (even likely) that your specification is that the internal LED's max-out at 4 volts with 10 milliamps.· In which case, as long as you drop the current with an in-line resistor, that could be all you'd need.
Can you post the model number of this opto-isolator?· Because it sounds like you're trying to use the MAXIMUM specification as the TYPICAL use·value -- which usually breaks things.
Post Edited (allanlane5) : 7/6/2010 3:33:51 PM GMT
Unfortunately, I don't have the model of the Opto as it's embedded in the printer, all I have is their interface specs. It does look like they already have a 100R resistor in series with the opto for current limiting though.
details I have:
Absolute Max rating:
Vi -4V = Vi = + 4V
Ii less than 30 mA, preferably 10mA
Input Drive conditions (binary states):
High (on) Ii = 3.4 mA @ Vi = 1.6V
Low (off) Ii = 100uA @ Vi = 0.4V
I thought to be safe I'll drop the voltage down to 3.3-3.6V, and limit the current to less than 10mA.
what I was thinking was to use 2 diodes and a resistor in series:
P0
WWW
opto interface here
0V
2 x In4148's and a 180R resistor which would take the voltage down to about 3.6-3.7V and the resistor would limit the current draw to about 10mA.
Am I right in my thinking??????? Is there any risk in the components overheating with these values?
thanks
Jon
The "input conditions" you've described sound a lot like "TTL" specifications -- which are intended to be run at "Vcc", aka 5 volts. What the "High (on)" number means is, any voltage above 1.6 volts will be sensed as a "1" by the circuit, any voltage below 0.4 sensed as a "zero". Any voltage in-between is "indeterminate", so don't leave the voltage there.
By dropping your voltage to 3.3 volts, you're reducing the amount of noise isolation in the line -- something you don't want to do.
Your equation "Vi - 4V = Vi = +4V" makes no sense to me at all.
It's main limitation may be speed. But I doubt that you'll encounter data rates from the BASIC Stamp that it can't handle.
But we haven't established that 5V to 3.3V conversion is really what the OP needs yet. Sure, HE thinks that's what he needs, but I strongly suspect he's misreading the interface specification.
here's the page from the printer's interface manual.
Jon
What do you expect the Xerox Production Printer to print off of a BS2p40?
And again, if you HAVE the printer's interface manual, clearly you could tell us the printer manufacturer (Xerox, I get that) and model number.
Post Edited (allanlane5) : 7/6/2010 8:13:52 PM GMT
Since the input is an optoisolator with (presumably) a 100R series resistor, we can compute from the V/I specs that the forward voltage of the LED is 1.26V. With an input of 4V (the max), the current would be 27mA (close to max), so that's consistent. For a 10mA current, the input voltage would have to be 2.26V. My circuit will work, but I'm guessing that a 270R series resistor would also do the trick.
Do I need to show my math?
my website is: www.pressus.co.uk
I've used the basic stamps in virtually every machine I've designed over the last 10 years or so. I say virtually, as I dabbled with the Prop for 1 system that needed multipule processors.
It's the 1st time i've linked to these big boy printers, so have to understand the 30 page interface manual!!!
Xerox have 1 interface spec for all their printers I am lead to believe. having read the manual from front to back the page I posted above is the only bit covering the input specs.
Jon
It would be SO much easier to use a +5 volt solution, but you don't want to burn out an expensive DFA hardware board. From your diagram, it looks strongly like an in-line resistor would drop the current and voltage enough for it to work "outbound" from the BS2 to the DFA. Recieving signals by the BS2 FROM the DFA looks very straightforward.
Exactly, I really don't want to destroy anything! The first time I will see the printer is when I plug my machine in at the customers site in mainland Europe. That's why I thought I would enlist the clever people on this forum. It seemed to me far too easy just to stick a resistor in the line!
Thanks to all of your help and the suggestions from everybody else.....
wish me luck!
Jon
Is not good idea?
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
