Free PCB software from RS!
RS has just launched DesignSpark PCB, a free PCB package:
uk.rs-online.com/web/generalDisplay.html?id=pcb&cm_sp=Homepage-uk-_-Online-Quotes-_-Primary-Banner
It's actually a version of a well-known PCB package that I used for over 15 years, from shortly after it was launched.
RS has obviously done it to annoy their main competitor, Farnell, who took over CADsoft (Eagle) a few months ago.
I'll be creating a Propeller part for it, based on my existing Pulsonix part.
Leon Heller
Amateur radio callsign: G1HSM
Leon Heller
The software has a few irritating omissions, like no buses, but it's quite capable of producing good results and is very easy to use.
I just created a DIL Propeller part, it's in these library files:
www.leonheller.com/DesignSpark/Library.zip
It only took me a few minutes, as I just had to create the schematic symbol, then copy and paste the pin names into the library editor from the Pulsonix library editor.
Extract the Parallax library files and add them to the DesignSpark library directory. I think you might have to tell DesignSpark about them, in order to use the part. I'll add the QFP part later.
Leon Heller
Post Edited (Leon) : 7/6/2010 6:49:48 PM GMT
Jim
Perhaps DesignSpark is meant to be the RS version of Farnell's Element14?
Wjsteele in the US, Farnell is associated with Newark / PremierOne, and RS is associated with AlliedElec.
Here is a nice review of it:
translate.google.com/translate?js=y&prev=_t&hl=sk&ie=UTF-8&layout=1&eotf=1&u=http%3A%2F%2Fwww.mikrozone.eu%2Fpluginy%2Fcontent%2Fcontent.php%3Fcontent.68&sl=sk&tl=en
The Google translation (from Czech, I think) is a bit weird in places, but it's quite readable.
Leon Heller
Post Edited (Leon) : 7/7/2010 3:32:01 AM GMT
Almost certainly as they have provided Eagle ULP's to convert Eagle files into an ascii format that can then be imported into Designspark.
@Leon
Thanks for the propellor library which I tried but DesignSpark uses .cml, .ssl, and .psl files for the component, symbol and the pcb symbol. The library folder also contains .ssx,.psx, and .cmx files but I'm not sure how they are related to the .--l files??
Paul
Post Edited (Paul M) : 7/7/2010 1:21:55 PM GMT
I'm tidying up that part, to conform with my usual standards for symbols.
I'll be creating a schematic for a minimal Propeller system, and a PCB. Perhaps someone else will beat me to it.
Leon Heller
Post Edited (Leon) : 7/7/2010 2:01:48 PM GMT
Bill
It's a good idea to create your own libraries for new parts. If you put them in the existing libraries and install an upgrade, you will lose them if the libraries are upgraded.
Here is the schematic of my minimal Propeller system:
www.leonheller.com/DesignSpark/Propeller.sch
and here is a PDF of it:
www.leonheller.com/DesignSpark/Propeller%20(Schematic).pdf
I found a minor omission in the user interface, a tooltip on the mouse pointer doesn't appear when it is placed on one of the Toolbar buttons. I've notified the developers.
Leon Heller
Post Edited (Leon) : 7/7/2010 10:05:06 PM GMT
