Non-Contact IR Thermometer
Has anyone tried one of these as a robot sensor to look for a human (or wall furnace!) in a cool location? Obviously very directional and much faster response than a PIR sensor.·Robot could spin slowly in place to scan·(probably turn, stop, turn) and look for a narrow band of·heat. Obviously works better in cooler locations. Could disable laser for safety, I·think that's just a sighting device for handheld use.
Any thoughts or user experience?
·http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=310230729990
For $40 it would be fun to play with just to see. You are the e-bay master!
Whit+
http://www.harborfreight.com/non-contact-laser-thermometer-96451.html
I played around a little with type of senser. The reading will drop off fast after about a foot.· At about 3 ft. it gets hard to tell if it would be a person or a warm wall. The big problem is, they don't have a serial output. So unless you want to·hook up a cam with software to read the LCD; they really of no value.
Al
http://forums.parallax.com/showthread.php?p=907553
and this thread:
http://forums.parallax.com/showthread.php?p=907557
Andrew Williams
WBA Consulting
PowerTwig Dual Output Power Supply Module
My Prop projects: Reverse Geo-Cache Box, Custom Metronome, Micro Plunge Logger
Mine updates about once per second possible a little less. When you release the trigger it holds the last temp then shuts off after maybe 15 seconds. It seems to have about a 1" sensing circle at about 3ft and appears to be fairly accurate. Bodies through clothes generally run about 83-86 degrees, so as long as the ambient air is cooler than that you'd be fine. Skin is generally about 89 degrees depending..... if the bot / sensor is low to the floor, I'm not sure what the temp is through jeans of shoes.....
It seems to be very light on batteries too. I don't use it daily, but I've never replaced the battery far as I know in 8yrs.
Maybe that'll help you decide.
Oh, my unit is not Harbor Freight..... hopefully the above will be relevant to the HF units.
"puff"...... Smile, there went another one.
Post Edited (Spiral_72) : 7/8/2010 3:18:27 PM GMT
