How do you add a bookmark to your code in the Prop tool?
Can't find a reference in the manual on how to add a bookmark.
Kevin
Bad spellers of the world untie!
Kevin
(Version 1.2.7)
Jim
PS It's in the built in help file in the Propeller Tool
Thanks Jim.
Jim
I use this regularly when I am scrolling around in the code comparing a couple areas or working on setting up I/O and need to grab the definitions from the CON or VAR section.
Timothy D. Swieter, P.E.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" 16:9 LCD Composite video display, eProto for SunSPOT, PropNET, PolkaDOT-51
www.tdswieter.com
Nyamekye,
It has that function.
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
People should be able to use any editor they like ... I do, but the Parallax font often gets in the way.
I never used bookmarks.
Propeller Pages: Propeller JVM
What I do is place comments on all my "PUB", "PRI", "CON", "DAT" lines and use "Summary" view to jump around.
I also subdivide CON and DAT sections to make this work better.
My Prop Apps:· http://www.rayslogic.com/propeller/Programming/Programming.htm
My Prop Info: ·http://www.rayslogic.com/propeller/propeller.htm
My Prop Products:· http://www.rayslogic.com/Propeller/Products/Products.htm
You can horizontally split the main screen and it is the same file. You can also drag a tab out from the main window to make a new window, but it will have to be a different file than the main window.
www.tdswieter.com
Maybe I've just been a casual observer in this regard.
When I use Propeller Tool it's version 1.2.6.
Nyamekye,
Thanks for asking. Now that I am looking at it I see my memory was wrong. You can split the screen horizontally or have two windows, but it will be a different file - not the same file. I was thinking the split screen was the same file, but it must be another software I was thinking of.
To split the screen with different files you have to do the following. In the Prop Tool have two files open. Grab the tab of one of the files and drag it away from the Prop Tool to create a second window. Or drag the file down the Prop Tool screen to create a horizontal split.
Now - if there was only a way to rearrange the tabs like one can in a browser such as Chrome or IE.
www.tdswieter.com
Cheers,
--Steve
