Propeller writing to SparkFun Serial LCD
I have the Propeller Servo Controller USB and a SparkFun Serial LCD. I was wondering if anyone has some example code for writing text/commands to the LCD. I've played around with it a little but got frustrated. Any help would be much appreciated.
http://www.parallax.com/Store/Microcontrollers/PropellerDevelopmentBoards/tabid/514/CategoryID/73/List/0/SortField/0/Level/a/ProductID/595/Default.aspx
SparkFun Serial LCD
http://www.sparkfun.com/commerce/product_info.php?products_id=9395
SparkFun Serial LCD
The code should turn on the Blinking Box Cursor and then write "Hello World!" to the LCD. Instead it prints "||Hello World!".
humm.........
CON baud = 9600 ' baud rate pin = 0 ' tx pin _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 LCD_BKSPC = $10 ' move cursor left LCD_RT = $14 ' move cursor right LCD_CLS = $01 ' clear LCD (follow with 5 ms delay) LCD_SET = $7C ' LCD Set Parameter LCD_BL1 = 128 ' Set backlight to 0% LCD_BL2 = 140 ' Set backlight to 40% LCD_BL3 = 150 ' Set backlight to 73% LCD_BL4 = 157 ' Set backlight to 100% LCD_SST = $09 ' Toggle Splash Screen LCD_SSS = $0A ' Save current screen to splash screen LCD_24 = $4B ' Set Baud to 2400 LCD_48 = $4C ' Set Baud to 4800 LCD_96 = $4D ' Set Baud to 9600 LCD_144 = $4E ' Set Baud to 14400 LCD_192 = $4F ' Set Baud to 19200 LCD_384 = $50 ' Set Baud to 38400 LCD_OFF = $08 ' LCD visual off LCD_ON = $0C ' LCD visual on LCD_CRON = $0E ' LCD cursor on LCD_CROFF = $0C ' LCD cursor off LCD_BXON = $0D ' Blinking box cursor on LCD_SR = $1C ' LCD scroll right LCD_SL = $08 ' LCD scroll left LCD_CRP = $80 ' LCD set cursor position + position OBJ serial : "simple_serial" ' bit-bang serial driver PUB init | Temp waitcnt(clkfreq / 4_000 + cnt) serial.init(-1, pin, baud) waitcnt(clkfreq / 200 + cnt) serial.tx(LCD_BXON) waitcnt(clkfreq / 200_000 + cnt) serial.str(string("Hello World!"))▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Harley Shanko
note that if your using the 3.3v lcd, it sometimes gets confused at power up if the usb plug is connected (on the demo board). To reset the lcd, remove the usb plug as well as power down the demo board.
Rudy's CNC Freeware·· http://www.enter.net/~schleinkofer
StevenG, you have to send $fe before sending a command byte.
