RF Transmitter/Receiver (#27980)
Hi, I was wondering if anyone could help me out quickly. I am using the Basic Stamp 2 with the RF Transmitter/Receiver. Is there anyway that I can send a signal/code to the transmitter that makes it send out a certain signal to be picked up by the receiver. We only have 1 set of transmitter/receiver so we cannot send a signal to one transmitter to receiver to transmitter...
Thanks for any help!
' TxCode_v_1.0.bs2 '{$STAMP BS2} '{$PBASIC 2.5} ' 'Parallax 433.92 MHz RF Receiver (#27981) Sample Tx Code (BS2) 'Connect Pin 8 of the BS2 to the DATA line on the RF module 'Connect +5v to the 5v line, connect Ground to the GND line 'This code will transmit two word sized counters, byte at a time. ' 'Note the PULSOUT instruction: this helps the receiver sync with 'the transmitter, especially after lapses in communication 'This code transmits at 9600 baud, inverted. x VAR Word y VAR Word DO PULSOUT 8, 1200 'Sync pulse for the receiver SEROUT 8, 16468, [noparse][[/noparse] "!", x.HIGHBYTE, x.LOWBYTE, y.HIGHBYTE, y.LOWBYTE ] x = x + 1 y = y + 1 PAUSE 10 LOOP▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
- Stephen
Post Edited (Franklin) : 7/1/2010 2:04:05 AM GMT
Keep in mind that there may be a lot of radio noise present and there may be errors in the information received. It's good practice to use some kind of error detection. There are some examples with links on the product webpage on the use of CRC (cyclic redundancy checks) with the transmitter/receiver. The use of "!" or similar lead-in character also helps. In simple cases, you could just send the same data two or three times with different lead-in characters to get the redundancy.
