Servos and Spin. problem found. php and spin do loops diferently.
This code is to control a camera turet that steps over a specific area. i run the test code that comes with the servo32_7 object and the servos work so it is not hardware. run my code nothing.
what it should do is pan from 0 to 360 deg(servo is geraed 4 to 1 to make this possible) and tilt from -45 to 45 deg then repeat changing positions every 1/4 second.
but it does not.
Lots of propeller based products in stock at affordable prices.
Post Edited (mctrivia) : 6/29/2010 7:06:30 AM GMT
but it does not.
