New Take on Pings for the Stingray
Instead of mounting 3 pings on solid bases on my Stingray I decided to mount two Pings on Parallax's mount kits #570-28015.· You can see in the pictures that I used Parallax's L-mounting brackets as well.· You can also see in the one picture I can check for side objects or follow a wall and know if the side is clear or I have cleared the wall.· I hope by moving the Pings and not having to move the Stingray its self to do Ping searches will help in navigation and maintaining a set course by minimizing object avoidance movements.· As far as I know I am the first to do this and just got them mounted tonight so code and test results aren't available yet.
I also mounted a HM55B Compass #29123 like shown in the mount kit manual
Note the use of neon zip ties to mark which wire goes with what servo. Very helpful when trying to diagnose hardware and programming errors.
Tony
Tony
···································Fix it, if ain't broke!
D Rat
Dave Ratcliff N6YEE
Thanks! I will share my code as soon as I have it working. I sure hope it doesn't take·too long.
Tony
Post Edited (Tony B.) : 6/26/2010 3:23:34 AM GMT
Looks great!
Whit+
$illy me, I just an$wered my own que$tion!
D Rat
Dave Ratcliff N6YEE
Great! I was hoping others would like the idea and come on board.· When you order don't forget four (4) of the L Shaped Mounting Bracket.· I used them instead of the ones that come in the bracket kit.· You will also need some 4-40 bolts and nuts to mount the servo/L-Brackets to the front panels.· I used my own supply, but Parallax or your local hobby shop should have some. I found it easiest to just take each panel out attach the servo to each panel and then replace it making sure to run the servo wire up the center hole.· That makes me think you might want to order three (3) Rubber Grommet-13/32" hold·for the wire holes in the front panels.·
You’re right on about battery usage.· That's why I am going to do like others have down and switch to an R/C car battery that I can easily recharge with the equipment I own.· It's what I used on two of my other robots I have designed.· http://forums.parallax.com/showthread.php?p=876789· http://forums.parallax.com/showthread.php?p=894042
What language are you programming your Stingray in?· I really like PropBASIC, but am also writing/translating code into Spin and·Spin into PropBASIC.· It can't hurt to be proficient in two languages and I hope it helps more individuals to get involved with writing code for the Stingray and Propeller chip.
Tony
I will be using spin. I have tried propbasic, but it has been so long since I have used my bs2 that I'm just used to spin/pasm.
Edit: Although I am just doing the pings, I have a different compass chip (hmc6352) and will put on the breadboard if I use it.
D Rat
Dave Ratcliff N6YEE
Post Edited (ratronic) : 6/27/2010 2:17:41 PM GMT
http://www.youtube.com/watch?v=SlGdk_FWJiU
Edit : fixed the descriptions for the right and left pings and wheels in the program
D Rat
Dave Ratcliff N6YEE
Post Edited (ratronic) : 7/4/2010 7:56:30 PM GMT
http://www.youtube.com/watch?v=ARj0CknHp-w
D Rat
Dave Ratcliff N6YEE
Whit+
