how can concat a numeric value onto a string
Hello everyone
i have a project that i am working on and sending the data over RF i can send a string but i want to place a number at the end of that string·
exmpale
its 90' outside
the 90 oin the string would be a number from my sensor.i have not started to work on the sensor part of the code but i can send a string over RF.
exmpale
its 90' outside
you don't have to concat it
just code
Serial.Str(string(""My Text")) Serial.dec(MyVariable)the value will be send right after the last character of the string
best regards
Stefan
BTW: my object does not have a way to convert integers to strings, but there are other objects that do that, such as Simple Numbers (included with your Propeller Tool).
April, 2008: when I discovered the answers to all my micro-computational-botherations!
Some of my objects:
MCP3X0X ADC Driver - Programmable Schmitt inputs, frequency reading, and more!
Simple Propeller-based Database - Making life easier and more readable for all your EEPROM storage needs.
String Manipulation Library - Don't allow strings to be the bane of the Propeller, bend them to your will!
Fast Inter-Propeller Comm - Fast communication between two propellers (1.37MB/s @100MHz)!
