I need a full-handshaking null modem cable. Any ideas ?
Bean
I lost the cable for my LPKF PCB mill.
I know I could build one, but I really want a molded cable.
It needs to be full-handshaking null modem. I tried two already and they didn't work because they were not full handshaking.
It needs a DB9F on one end and a DB25F on the other.
I'd like about 12 to 15 foot long, but I'll take anything right now.
Any ideas where I could buy one ?
Bean
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
There are two rules in life:
· 1) Never divulge all information
If you choose not to decide, you still have made a choice. [noparse][[/noparse]RUSH - Freewill]
Bean
It's only 10 feet, though. You might be able to get a longer, more standard cable and put an adapter on one end.
I have used them though not for serial cables.
Jim
PS I'll be passing through PA, maybe I can drop it off.
Are you aware of what a full crossover requires? Of course there are variations, but this is the true (mainframe computer) crossover. I am presuming async...
GND
GND
TXD
RXD
RXD
TXD
RTS & CTS
DCD
DCD
RTS & CTS
DTR
DSR
DSR
DTR
For sync you need to add clocking
TXC
RXC
RXC
TXC
Sometimes external clocking is provided on (pin 24???) which is wired to all TXC & RXC.
