Need Help with Eagle pad size
Help.
I need to be able to change the pad size for all my resistors to be larger so that it is easier to solder.
But I don't want to use a custom resistor package for each of the many resistors on the board.
What is the easiest way to change the pad size for all the 1/8 watt thru hole resistors in one go?
Thanks.
www.fd.com.my
www.mercedes.com.my
Thanks.
www.fd.com.my
www.mercedes.com.my
In Eagle, I just quickly checked and they are all the same sized hole. Pretty big though, almost as wide as a DIP16 pad. But there is nothing stopping you creating a new part. I did it recently for a 16 led starburst display. I looked up how to do it on Instructables.
I presume you mean Eagle since it is in the title?
I guess the other question - are you getting the PCBs made professionally, and if so, they will have a solder mask? Having soldered both bare boards and solder mask ones, I can say that I *love* solder mask.
www.instructables.com/id/How-to-make-a-custom-library-part-in-Eagle-CAD-too/
Post Edited (Dr_Acula) : 6/22/2010 11:55:59 AM GMT
As in the DRC, there is a Shapes tab. You can adjust various settings here to make pads larger/smaller. I've always used my lirbary as the default, so I can't offer much advice on using these settings, but it appears that you can use it to force the pad larger (not the hole size - hole size can only be edited in the part library.)
Timothy D. Swieter, P.E.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" 16:9 LCD Composite video display, eProto for SunSPOT, PropNET, PolkaDOT-51
www.tdswieter.com
www.fd.com.my
www.mercedes.com.my
