Bug with PropBasic ?
Hello all
·I not sure if its a bug or I'm doing something wrong.
When I send out a VAR like this·%0000_0001 I'll get this·%0000_0001 back?, If I send %1000_0000 then·I'll get this·%0001_0000 back.
This is messing up all of my shift reg. code and my SEROUT/IN code.
In the test the LSBs come in order %0000_3210. But the MSBs are reversed %4567_3210 with the buttons pressed in order from pin7..pin0.
Yes the LED pins are in order from pin15..pin8 ???
·I have attached a sample code using LEDs and buttons to show this in more detail.
Any help with this would be great!!!
Thanks in advance
The Truth is out there············___$WMc%___···························· BoogerWoods, FL. USA
want speed?·want·to use the Propeller?·want to stay with BASIC___www.propbasic.com___
You can feel stupid by asking a stupid question or You can be really·stupid by not asking at all.
Thanks in advance
That said, I simplified it like this:
Jon McPhalen
Hollywood, CA
Bean
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
There are two rules in life:
· 1) Never divulge all information
If you choose not to decide, you still have made a choice. [noparse][[/noparse]RUSH - Freewill]
Well; ·Now I'm really confused. I don't see why the first 4 bits on the right are in order and the second 4 bits on the left are reversed?
·I have included a hardware drawing of what I have set-up on the Propeller Pro. Dev. Board and a little chart to show the LED that gets lite from what button is pressed in the code I posted earlier.
·If You can find the time to look at My little drawing posted below,I would really appreciate it.
Jon McPhalen
Hollywood, CA
I've looked at the generated code, and I don't see anything wrong.
Like Jon suggested, triple check your wiring.
Bean
I was just curious, what the compilation result is.
(I do think too, it should be a wiring issue here.)
But I have seen, that every LED line is switched to LOW for the time of one instruction.
················· mov·········· __temp1,ina················· '· LEDs = buttons
················· and·········· __temp1,buttons············
················· shl·········· __temp1,#8·················
················· and·········· __temp1,LEDs···············
················· andn········· outa,LEDs·················· <<<<<<< switch to low!!!
················· or··········· outa,__temp1
I think, this is a trap, because it can generate very short additional pulses.
Christof
Yeah, I know, it's just that it takes two more instructions to do it glitch-free.
I guess I should change it though....
Bean
After reading Your post replies, I started investigating My wiring further.My wiring was good. I had some other devices on the board and some of them were wired to the I/O pin groups in the VGA pin group of the PropProDevBoard. None of these pins where shared (only 1 jumper wire per pin) But I seem to remember mixing resistors for the VGA output.
I know now this is a hardware issue and not a PropBasic software issue.
I now have a working code that does what I expect it to do.(with the other hardware devices removed)
Many Thanks
Post Edited ($WMc%) : 6/25/2010 11:13:05 PM GMT
