Looking for a socket/socket 0.1" adapter
Timothy D. Swieter
I have designed this great product for Brilldea. I'm very excited about it. On the product is 0.1" right angle headers for the various connections required to the device. The primary connection means to the device will be a cable with individual conductors and an appropriate 0.1" housing with socket pins. Then when the header and housing are mated on the PCB, the housing doesn't hang off the board. That is to say that the 0.1" header is set back from the boards edge by about 0.55".
Now - I had a bit of inspiration strike for an accessory design for this new product. The accessory though, I would like to mate directly to the main PCB without a cable. Naturally, the part needed would be a PCB mounted, right angle socket. However, the sockets that I am seeing from SAMTEC and others in the Digikey catalog have a housing length of 0.35 inches. The right angle housing can be mounted right at the boards edge of the accessory, however it still comes up short from fully mating with the header.
So - I am wondering if there is such an adapter as a socket to socket housing adapter and then I can put right angle pin headers on both the main board and the accessory board. I haven't seen this type of part for electronics before, but there is so much I haven't seen.
If such a device doesn't exist (or is expensive) I will have to go the route of using a really short cable or find a socket housing that is longer than 0.35".
Timothy D. Swieter, P.E.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" 16:9 LCD Composite video display, eProto for SunSPOT, PropNET, PolkaDOT-51
www.tdswieter.com
www.tdswieter.com
Perfect!!! Sometimes I get so fixated on a particular solution I can't see the proper solution right in front of me. I was staring at the SSW/SSQ datasheet last night and kept wishing for a socket/socket header.
www.tdswieter.com
www.tdswieter.com
Over the next couple of days thought I had several confusing and conflicting e-mails. One e-mails asked me to log in and pay for the samples. I did, it was only US$2 or US$3 dollars - no biggie.
A couple days later I went to my office where I had the samples shipped. I had a UPS packages from the USA with the samples in it. I also had a UPS package from some where in Asia with samples in it. I think somehow my sample order was passed to the Asian office and then double processed by both the USA and Asia.
So - overall, yes they covered shipping.
I have since met up with a Samtec rep from the Singapore office. Next week I am getting together with him and he is bringing the samples with him.
www.tdswieter.com
