battery holder parts where to find
I want to make my own battery holder. Anyone know where I can get the metal parts cheap.
Lots of propeller based products in stock at affordable prices.
I found some cheap battery holders and I'm starting to think:
http://www.parts-express.com/wizards/searchResults.cfm?srchExt=CAT&srchCat=64&utm_source=google&utm_medium=cpc&utm_campaign=G+-+RKG+Keywords+10-01-07+(Search)&utm_group=30749305:+Hobby/Project+WC&utm_term=battery+holders
You should probably buy a mess of these, Mctrivia and sell them at a profit like all of the other sites do.
While we are talking about battery parts, do you know where I can find this 9V battery holder with switch & 2.1mm plug instead of having to pay $4 to one vender:
http://www.adafruit.com/index.php?main_page=product_info&cPath=17_22&products_id=67
Chuck
@Phil Pilgrim, as you can see I've got the black oxide machine screws. I had to order the terminal blocks from Gadget Gangster.
Post Edited (lardom) : 6/21/2010 3:51:55 PM GMT
For large quantities it is cheapest to find a company that will do injection molding. You will pay a large setup fee for the molds but a very low cost per unit.
I charge no setup fee but it takes a fairly long time for me to build stuff(the custom boxs for rays LCD screens take 3.5 hours) so the cost per unit is higher. Depending on accuracy needed and size my cost per unit starts at $10 each. I could build you device box with built in battery box for $15. You may be able to find an off the shelf box that may do for less.
Positive Pole w/Tab Battery Contact
search.digikey.com/scripts/DkSearch/dksus.dll?Cat=393339&k=5226K-ND
Negative with Coil&Tab Battery Contact
search.digikey.com/scripts/DkSearch/dksus.dll?Cat=393339&k=5204K-ND
Third pic is of the case they were used in
Andrew Williams
WBA Consulting
PowerTwig Dual Output Power Supply Module
My Prop projects: Reverse Geo-Cache Box, Custom Metronome, Micro Plunge Logger
Andrew Williams
WBA Consulting
Post Edited (mctrivia) : 6/22/2010 10:51:35 PM GMT
Post Edited (mctrivia) : 6/22/2010 10:51:14 PM GMT
B=66mm
G=30mm
E=30mm
'A' looks like the battery compartment. The perf board and the RJ11 connector will fit easily inside "E". I don't even need the standoffs indicated @ "K" and "L".
· I would leave the configuration of the battery compartment up to you. Your expertise would be better than what I could come up with. I especially like the idea of a battery lid. I will order two if the set-up for the second box is easier. (One is fine) I can complete my prototype with what I've seen and I've started ordering supplies for two machines.
this box was designed with a 9v battery in mind where you have a connector on the end of a wire
search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=BS12I-HD-24AWG-ND
no special config needed. AA batteries require chambers for the individual batteries with connectors screwed to the walls.
