UPEW 2010: Project Help Request List?
WBA Consulting
While at UPEW, I will have a few projects that I will be hunting down experts to pick their brains. I thought maybe a list could be created of anyone's projects in case those that are able to help would like to focus their "free time" during the event. Maybe we can put a whiteboard somewhere at the event so people could put up their name and requests? Anyhow, to kick this off, here are my two projects that I will need help on:
1) Full duplex serial usage with a Symbol LS1220 serial barcode scanner for RX and a Zebra serial printer for TX
2) Demystifying I2C for a newbie so I can work with Sensirion's new SHT21 sensor that uses true I2C for communication. I have samples built up on PCBs and would love to be able to publish an object for the SHT21 before it's publicly released.
Andrew Williams
WBA Consulting
My Prop projects: Reverse Geo-Cache Box, Custom Metronome, Micro Plunge Logger
Andrew Williams
WBA Consulting
Want to share code and ideas?
OBC
Propeller Feature Projects: PropellerPowered.com
Visit the: PROPELLERPOWERED SIG forum kindly hosted by Savage Circuits.
I just got Harprits' book in the mail today(Programming the Propeller with Spin)!!! I just thumbed through and found great stuff in there about motor control and PID feedback and quadrature encoders. Exactly what I am working on right now.
I also just ordered an SPT200 pan and tilt from ServoCity with a couple HS645 servos like what you were talking about on the other thread. We will have to share notes.
Timothy D. Swieter, P.E.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" 16:9 LCD Composite video display, eProto for SunSPOT, PropNET, PolkaDOT-51
www.tdswieter.com
did a search for the manual at symbol
search LS1220 at symbol
searchresult
on page 9-22 there start the RS232 options
simply scan the barcodes to configure the scanner to
- baudrate
- parity none
- hardware handshaking no
- software handshaking no
- one stopbit
use a PC-terminal-software to test the configuration of the scanner
DON'T use the propeller right now but the PC as the PC and a terminalsoftware is known as working properly
best regards
Stefan
Andrew Williams
WBA Consulting
cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=250649211954&ssPageName=ADME:B:EOIBSA:US:1123#ht_603wt_930
Hopefully it'll arrived just in time to pack it in the suitcase and bring it with me for Saturday night.
Rumor has it that this has RX/TX points on the board in the base unit.
OBC
Can't wait to see that in action for moving a mouse cursor.
Is the interface physical or mental?
Propeller Pages: Propeller JVM
According to the box, mental.. Gramps and I are in a little debate on if this is real or not. [noparse]:)[/noparse]
I'm expecting simple step EEG sensor myself.
OBC
The current project consists of two robots, each with 10 Ping sensors. I'll have the whole thing set up in the conference room attached to the main UPEW meeting space. These robots both have Xbee modules to send data back to a base station which displays the data on a VGA. Additionally, a hand-held controller for each robot uses a switch to go between autonomous/remote control mode. Everything functions according to my design goal but my coding techniques are primitive and sloppy. Therefore, I'd like to address one (1) piece of the code that really needs improvement: the autonomous roaming code with Ping sensors. Here's the basic idea:
1. From a stopped position, robot in autonomous mode decides to move forward or backward. <= done, works well
2. Read the five (5) Ping sensors and generate a basic map of obstacle location and proximity. Replace my clunky IF statements with a few proportional control calculations which allows the robot to move in a more fluid fashion. <= this is where I need help. There's got to be a more elegant way of achieving my goal than the present approach.
I'm looking for some help on Saturday evening to improve the navigation code.
Parallax Inc.
Follow me at http://twitter.com/ParallaxKen for some insider news.
Tim,
UPENE (Norwalk, OH) is scheduled for the end of August - http://forums.parallax.com/showthread.php?p=896865
I will be there, hope to see you then.
Art
I'm not positive I will be there. I am hoping, but many factors have to align for it to happen. Perhaps I will attend virtually.
www.tdswieter.com
If you are able to make it, stop by and introduce yourself.
Art
Side 1) Speaker list and Expo Agenda
Side 2) Help request list and exhibitor map
Side 3) ?
Side 4) ?
Andrew Williams
WBA Consulting
PowerTwig Dual Output Power Supply Module
It is Propeller powered and features two HB-25 motor drivers, two Position Controllers, a 16 button keypad, 2 x 16 LCD display and a Micro SD card. It weighs about 150 lbs.
I have a lot of plans for it but the first thing I wanted to do was to be able to use the keypad to enter a series of commands for it to follow - just like a Big Trak.
Anybody interested in helping out? The "Cat Door" project that I have been working on with my boys has taken longer than I planned for.
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
