Morse Code Clock
Hi Folks,
Here is my second project using the Propeller. It is a Morse Code Clock/Lamp. I had a lot of fun putting this together and I learned a lot too. Source code and schematic attached.
www.youtube.com/watch?v=vQwGw0s2qAc
John
John
My wife suggested mounting the light into a model ship...
Beau Schwabe
IC Layout Engineer
I wasn't envisioning a clock that was always on, but one that you pressed to check the time. The switch that came with the lamp is a toggle though, pressing it again does turn it off. I would have preferred an always open tact switch. It's just a novelty project to learn spin, I probably won't go through the effort to fix it [noparse]:)[/noparse]
A model ship, what a great idea! I was thinking how awesome it would be to have a real ship lamp with a fresnel lens.
Thanks!
John
Depending on how the switch in the lamp is made, you may be able to remove the latching spring to make it a momentary switch that just triggers the time display.
Andrew Williams
WBA Consulting
PowerTwig Dual Output Power Supply Module
My Prop projects: Reverse Geo-Cache Box, Custom Metronome, Micro Plunge Logger
Thanks for your kind words!
John
Ohhh!!! If you mount the light on a ship you need to do away with ALL of the set buttons, and just have a light receiver on it as well. You 'set' the time by sending it the time in morse code with an ordinary flashlight!!
Beau Schwabe
IC Layout Engineer
This forum is the greatest.
John
If the light is wired as a separate output and the switch is wired as a separate input...
Then you can achieve a toggle effect by remembering the switch state the last time it changed.· Each time the switch changes state you can store that state and flash the time once.· Then wait for the switch to change states so you can repeat the process!
· - Sparks-R-Fun!
Thank you for sharing it
Very inspiring, considering it's only my second attempt to build something with the Prop.
John
Perhaps audio output on the hour/half hour during the day time, like a good old chiming clock.
www.parallax.com
Jim
Wow, Project of the Week! Super cool.
John
