So now its working but with annoying bugs, please help!! PARALLAX RFID READER
TO Jim,
Thanks so much for those links! I owe you tremendously for setting me on the right path!!!! I used the VB program and finally realized that I needed to use PORT 1! I was just trying 4 or 5 which are listed as the 'virtual' COM ports. I guess 'virtual' is the key word. I was so hyped to get ANY response from my computer! So really, thanks!
Alright, but now I have three new problems with my RFID Reader if anyone can help.
1. When I scan a transponder I get a weird output to the screen i.e: 'FPuP??FdF3525' <--- this is just an example from memory but I know there should not be question marks in the key codes. Also, if I scan the same card numerous times I will get slightly different outputs? WTF. However, when I used the reader in hyperterminal I did get 'normal' key codes with no question marks. again, WTF!?
2. After I've scanned about 4 - 5 codes the reader seems to jam up and not work unless I unplug it and the close & open the port. I'm using a power converter that plugs into the wall that I salvaged from a router. Its 5 volts and .4 Amps, could this be too much for the RFID card?
3. Due to the previous issues I decided to build the more advanced schematic that has the 'DTR (Data Terminal Ready)' Option but when I choose enable the reader goes green (meaning its not reading) and when I choose disable the reader goes red and is ready to read. So in otherwords, its like its working backwards. When I choose to connect the reader closes down and when I disconnect the reader powers up. I'm nearly sure I just have something backwards but I've tried to check everything. According to the schematic the emitter on the 2N3904 transistor is connected to a ground but its not connected to the negative of the battery. In my previoius post I explained that I'm fairly new to electronics , especially building circuits so in this case what should the emitter pin be attached to (In layman's terms). Also, another possibility Parallax says to use a NPN 2n3904 Transistor but should I be using a PNP 2n3906?
THIS IS THE LINK TO THE SCHEMATIC FOR THE INTERFACE I BUILT
- Stephen
http://forums.parallax.com/showthread.php?p=727719
and the schematic for the interface is
http://forums.parallax.com/attachment.php?attachmentid=46147
Chris Savage
Parallax Engineering
-- BEn
THIS IS OBVIOUSLY THE SCHEMATIC I ATTEMPTED TO BUILD
Your question about the emitter of the NPN 2N3904 , this should be common to pin 5 of the DB9 connector and the GND of the RFID connector , the GND of the RFID connector should have the negative wire connected from your power supply. In this particular instance it might be easier for you to think of the GND connections of the schematic as being negative connections.
Your circuit contains the DTR enable/disable option (Q2) , its important that whichever terminal program you use has control of the DTR signal or your RFID may not work correctly. I am unsure whether you have this option under Hyperterminal but the Parallax RFID software does and should work with your reader.
Try and verify the RFID is reading to begin with , use the two transistor interface that you built and double check the placement of parts and the integrity of the solder joints. Take a piece of wire and jumper the /Enable pin of the RFID connector to GND (negative). This will permanently enable your reader , now you can use any terminal program set at 2400 baud rate to test incoming data.
What I would look for now is repeatability using just one tag·. Depending how the terminal program you use is set up it could be possible to receive a ? displayed on the screen. Try this with one tag and record the results exactly so that you can post them back here. Vary the distance and interval between swipes , see if anything works .
Jeff T.
