WiFi on the Prop? Could a USB WiFi be used?
Cluso99
Has anyone used a cheap WiFi module on the prop?
Could a cheap USB WiFi stick be used? Maybe Micah can answer this.
The ZigBee modules would be good, but they only communicate amongst themselves. I would like to be able to communicate with other WiFI devices such as the iPhone, iPad, PCs, and the ZipIt2.
This·link http://www.geek.com/articles/gadgets/parrot-ar-iphone-drone-20100616/· prompted this (from the QuadCopter thread·http://forums.parallax.com/showthread.php?p=890157 )
http://www.sparkfun.com/commerce/product_info.php?products_id=9290
or bluetooth
http://www.sparkfun.com/commerce/product_info.php?products_id=9913
Propeller Pages: Propeller JVM
WiFly GSX 802.11b/g Serial Module - Roving Networks
Bluetooth Module SMD - Rayson BTM-182
best regards
Stefan
It has both an inbuilt chip antenna and external connection. A bit expensive. I am unsure how much power is output compared to a Radio Control unit. (Yes, I would like to consider it in my QuadCopter although I have a DX6i)
A USB to WiFi is much cheaper ($10 on eBay). However, probably a lot of code is done on the PC.
I also thought about the higher power ZigBee modules but they are not WiFi compatible so need one each end. They are cheaper though and I think the higher power version may be better than the WiFly for distance.
It outputs 18 dBm. That is, near of 63 mW
Some ideas:
IF there where some way to connect a PCMCIA card to propeller, maybe you can do something like this:
http://www.iosoft.co.uk/wlan2.php
Some time ago, there where Wifi Cards with Compact Flash pinout. p.e. the Sony Cli
Unfortunately my RC gear does not state power out. Maybe I can find out online (later).
including shipping.
If someone could work up a WiFi to serial package using
one of these so that any uC could easily use WiFi, it would
sell well at a low price.
Put it on a small board with a prop and connect an RPSMA
connector for external antenna. Something like a mega1284p
might work better than the prop though, cheaper and 128kb flash,
16kb ram and probably fast enough at 20mips.
Getting detailed info on the WiFi dongle would be a huge help.
Might not have to use the USB interface at all if you had enough
understanding of what the uC on the dongle was doing and what
it expected Windows to handle.
I have not checked, a quick google might turn up some geeks
playing with these cheap WiFi units.
www.microchip.com/wwwproducts/Devices.aspx?dDocName=en548014
They recently took over the ZeroG company that developed them.
I've got an earlier version of it on a PICtail board, but haven't tried it yet.
Leon Heller
Amateur radio callsign: G1HSM
The Truth is out there············___$WMc%___···························· BoogerWoods, FL. USA
want speed?·want·to use the Propeller?·want to stay with BASIC___www.propbasic.com___
You can feel stupid by asking a stupid question or You can be really·stupid by not asking at all.
Do you have the part number on this bridge? Are you talking a small module, or a large consumer-size device like a Linksys WET54G ?
I have a few ENC28J160-based designs and would be interested to find a nice way to convert them to wireless...
Scott
Do You have some simple serial to WiFi code You could share here using the "WiFly GSX 802.11b/g Serial Module - Roving Networks "
I have looked a the Doc's for this module, But I'd like to some code that works with it as well, Something Parallax Micro friendly. Before I shell out the $money.
You said You "couldn't resist to make this as working links". If Your promoting this product, Now is Your chance to shine.
Thanks in advance for any help with some simple code to use this module!
Leon Heller
Post Edited (Leon) : 6/21/2010 9:13:13 AM GMT
