BOEn needs to pull high on Prop2 for a Prop to Prop connection? — Parallax Forums
MacTuxLinMacTuxLin Posts: 821
edited 2010-06-18 12:53 in Propeller 1
Hi All,
May I know if you need to pull high the BOEn if I'm loading a firmware from another Prop? Sorry if this was asked before. Thanks.
    edited 2010-06-18 11:10
    MacTuxLin said...
    Tying it to Vss (ground) works just fine (no issues here between Demoboard/RAMBlade and SpinStudio/M-Module(s)).
  • MacTuxLinMacTuxLin Posts: 821
    Got it. Thank you Kuroneko.
