Modifying a servo to operate relays.
Gramps
Open the servo.
CAREFULLY disassemble it.
CAREFULLY unsolder the motor.
CAREFULLY stretch out the pot wires.
Mark one lead with whiteout.
Cut the pot off about half way up the leads.
Solder the three wires extension to the pot reconnecting the board.
Solder two wires to the motor leads on the board.
Add a bicolor diode to the motor leads.
Plug the servo into the stamp board and test.
More photos on next post.
Gramps
'What is your life?"
"It is even a vapor that appears for a
little time and then vanishes away."
Saint James 61 A.D.
Gramps
Saint James 61 A.D.
Forward = Green
Reverse = Red
Regards, Gramps
Saint James 61 A.D.
