1 wire problem
Hi, I've got a problem with initializing objects in my program.
The problem is that if i initialize them in my start method, the 1 wire comms will not work correctly but if i initialize them in my main method, it works fine.
Does anyone know what might be causing this?
OBJ text : "tv_text" ow : "SpinOneWire" PUB start 'text.start(12) 'ow.start(3) main PUB main | i, numDevices, addr1 text.start(12) ow.start(3) text.out($00) ....... .......etc
Not really. What happens if you give start some local variables (like main), just to see if perhaps some code is accessing the stack in a buggy manner.
Pullmoll's Propeller Projects
Jon McPhalen
Hollywood, CA
I'm currently working on a project which is using a few objects for reading IR codes, serial comms, keyboard input, reading and writing to eeprom and tv text. The only part that wont work is the 1 wire comms. I beleive it may have somehting to do with the direction change of the pin (input/output) throughout comms. I might try a different 1 wire comms object which uses a seperate cog to see if that helps
Another question. how long does it take to stop or start a cog?
That should be in the order of 512 * 16 cycles + some more IIRC. 16 cycles is the hub window and there are 512 longs to be copied or initialized to zero. Someone else may know better.
Thanks, as long as it's faster than the human eye can see it should be fine for my project.
The program is working fine now in PASM
