Transmitting IR Remote Signals with the BASIC Stamp 2
Hi
Basic stamp can receive or transmit IR signals. I need that my bs2 is Transmitting IR Signals. I find how but i need NE555N timer IC. I dont have it. Is it possible to make that BS2 is Transmitting IR Remote Signals without NE555N timer IC.
i only need is simple IR Transmitter of Sony remote signals.
thanks
thanks
Bottom line -- the "Sony Remote Signal" is not "simple" enough for the stock BS2. Perhaps one of the faster BS2 flavors could do it.
You could drive the Ir LED directly off the BS but you likely won't get much range that way. Chances are you'll need to switch power through a 2N2222 or similar transistor. MAKE SURE YOU USE A CURRENT LIMITING RESISTOR [noparse]:)[/noparse]
Without looking it up, you'll need to modulate that Ir LED somewhere around 38 - 40kHz
Another cool trick [noparse]:)[/noparse] You can't see Ir light, but any video camera can..... including the cell phones [noparse]:)[/noparse] Awesome for troubleshooting!
"puff"...... Smile, there went another one.
http://forums.parallax.com/showthread.php?p=759751
A·555 can send a·very strong IR signal, its output is·~200 mA, where a Stamp pin is only 20mA. Excellent 555/556 info at http://www.kpsec.freeuk.com/555timer.htm
That is to say, a BS2 can receive, but not directly transmit, standard Sony codes, unless you attach an external circuit to generate the 38 kHz carrier signal.
But if your receiver/controlled item is another BS2 decoding the IR tone bursts (instead of a Sony TV set), you are not married to the Sony code, you can make up any code you like, and use the BS2 as a transmitter directly without an external oscillator.
One way to skin this cat would be to use the Sony codes, tailored to the BS2's relatively long minimum FREQOUT pulse. Keep the same pulse pattern, but use 1 ms and 2 ms pulses instead of 300 and 600 uS pulses. Obviously Parallax' well-documented ReadIR code routine would have to be modified, and the transmitting BS2 would use a series of FREQOUT pin, 38000,1 and FREQOUT pin, 38000,2 commands, separated by short uS pulsouts on an unused pin per the code in my link above.
thx
