Radio Shack Electronics Kit
Hi Everybody!
I've been playing for about a week with my new Propellor Education kit and I was wondering if there was any reason why I couldn't use my Radio Shack Electronics Lab (this one) for my breadboard - it has LEDS, Pots, buttons, speaker, buzzer,·etc already threre ready to go
the only thing is the row at the top that supplies various voltages has 1.5V, 3V, 4.5V, 6V, 7.5V, and 9V - would the 3V be good enough ir is 3.3V absolutely necessary?
Check out my CNC (and more) projects at http://www.backyard-workshop.com
The early bird gets the worm but the second mouse gets the cheese.
BUT only if it is stabilized Power supply
Regards
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
Then you'll have a "known" safe voltage for your Propeller.
Personally, I love the idea of converting this kit to the Propeller. What voltage at the LED's?
OBC
Propeller Feature Projects: PropellerPowered.com
Visit the: PROPELLERPOWERED SIG forum kindly hosted by Savage Circuits.
The Propellor chip fits just right too LOL there are 16 rows on the RS breadboard!
Jamie
I am using one piece ('cause that's all that would fit) of the breadboard to give myself a little more breadboard area - I put it over the little window for the tramsformer - what do I need to see that for anyway? LOL
The circuit that's on right now is the first blinker test - worked like a charm [noparse]:)[/noparse]
Thanks again for the tips guys -I'll be back I'm sure as I dig into things [noparse]:)[/noparse]
Jamie
Check out my CNC (and more) projects at http://www.backyardworkshop.com
I have one of them also, there great kits. The LED's (as well as every other item on board) have spring clips to attach your wiring to. So it is up to you what Voltage you feed them. They have built in resistors to limit the current. What I found more valuable is the text books with example circuits that comes with it. I got mine second hand, but would love to get one with all the goodies still in it!
I made up a small power supply module that snaps in and out in a second. Its a snap in no brainer.
Pic attached.
Harprit
Post Edited (Harprit) : 6/16/2010 2:21:35 AM GMT
That's a pretty good idea to use the radio shack kit. I'll have to break mine out.
kindof like a poor mans ppdb.
Since the power regulators use so much power, and non-rechargable batteries are so expensive, why not use NiMH batteries in it, which would put the 4.5V output at 3.6volts?
So I built two little modules that accepts a wall wart 2.1mm plug and provide the 5.0 or 3.3
volts as needed. They fit on breadboards, the pins on the right are not connected to anything,
the just help to anchor the thing in the breadboard. The blue connector provides external
off board power capability.
Harprit
