Anyone know were to get aluminum PCB made?
I need a perfectly flat plate 100x100mm that I can heat up to 110 C. I think my best way to do this would be to take a PCB and wind a long thin trace as a heating coil. But to dissipate the heat evenly I would want it to be aluminum core PCB. Anyone know were I can get some made at a reasonable price?
Lots of propeller based products in stock at affordable prices.
How flat is perfectly flat (1 mm, .1 mm, 1 wavelength?), and what are you trying to heat up (i.e. how fast will the heat get sucked out)? The answer to what you need is a lot different if you're trying to boil water or warming a piece of plastic for forming.
Can the flat plate be larger? Beyond the flat portion, can there be anything sticking up? How portable does this need to be? What is the power supply?
My first thought would be using some type of electric pan/pot with a heating coil built in.
John R.
Click here to see my Nomad Build Log
So the answers to your questions are: I am heating up plastic, using a computer power supply, it can not be any bigger then 100x100. The current design that is available heats up extremely slowly but that is not the biggest problem. It is not very flat, and has 6 bolts on the outsides shrinking the working area to only 80x100. I have designed a better control system then they utilized so that I can provide more current without taxing the print heads auxiliary power mosfet like the original design does.
I will mill up for you an aluminum plate 3/8 thick and your 100x100 mm if you like. I can also drill and tap holes into it at a pattern you specify.
If that is too thick, I also have 12, 16 and 20 gauge aluminum sheet that could work. Also I have a selection of stainless sheet, as well as an electric discharge stud welder to "pop" threaded studs onto it if that works. Since I'm in Canada, the shipping would be easy.
Let me know.
Cheers,
Peter (pjv)
www.amazon.com/Nickel-Chromium-Wire-30AWG-Content/dp/B000FN0HZA
Have you checked the width vs. resistance vs. amperage for the size trace you would need to do this? It might push the limits of what you can do.
Maybe check out Mcmaster-Carr and search for "DC Voltage Flexible Silicone-Rubber Heat Strips", page 511 I think. www.mcmaster.com/
Watt density is 5 watts/sq. in. They have 1-ft. wire leads for hardwiring. Max. heat output is 300° F. Exposure temperature range is -40° to +300° F.
They're flat and somewhat flexible. You can probably control them with a PID and PWM. They have a 12 volt and a 24 volt version and, of course, if you can find the original supplier, then you'll probably be able to find them with all kinds of bells and whistles (built in thermistors, etc.)
Hope that helps.
Post Edited (ElectricAye) : 6/12/2010 2:21:41 AM GMT
Do you have any idea how it's designed, if it uses regular trace copper, etc. or some special process? I'm very curious because if I can make my own micro heaters from PCBs, I would be a happy camper, too.
I found this but it may not be what you want:
Polyimide High Temp. Adhesive Tape 8mm
This heavy duty heat resistant tape can withstand temperatures up to 500 degrees Fahrenheit, 260 degrees Celsius. Used most often for attaching Nichrome wire to the heater barrel. This roll measures 8mm(0.315in) wide, and 33m(36yd) long.
$4.00
http://ultimachine.com/content/polyimide-high-temp-adhesive-tape-8mm
Chuck
That's interesting. I'd be happy to look at any information on this that you wish to post - amperage, voltage, trace widths, watt density, etc. If this is an off-the-shelf capability, then it would be a big help.
Mark
www.thingiverse.com/thing:2041/
has the schematic and pcb layout. heating trace is designed to be 6ohms. I want to design similar version with several parallel 6 ohm traces to double the current consumption so it will heat up much faster.
Thanks, mctrivia,
this is an eye opener to me and I'm trying to figure out why I couldn't get similar results with expressPCB some months ago - maybe minimum trace widths are too big. I can't tell from the info on your link what the trace width is for this Cupcake pcb. Would you mind taking a look at that? I don't have the Eagle software or whatever that this requires.
That would be great.
Much obliged,
Mark
I think I found out the supplier to McMaster for those silicone heaters. Have a look at these guys, located in Connecticut, USA:
www.electroflexheat.com/siliconerubberheaters.html
There's a link to their stock heaters at the bottom of that page.
They also have Kapton heaters.
The small ones I received yesterday from McMaster have an adhesive backing, but I'm sure you could get them directly from the supplier without the sticky stuff.
The max temp on the McMaster site says good to 300 F, but the ones I got state they're good to 210 C, which is about 410 F.
have fun,
Mark
