Need help with Amp Meter — Parallax Forums
Patrick DPatrick D Posts: 62
edited 2010-06-15 11:54 in General Discussion
A few years ago I built a BS2 Christmas light controller based off of Eric R's post:
http://forums.parallax.com/showthread.php?p=560479
It works great.· I would like to add an analog amp meter - so I can get a visual indication of how much current the lights are pulling.
I found an inexpensive panel mount analog meter (0-20A) but after reading I see that it requires a shunt.· After some research I am confused as how to determine the proper shunt to purchase.·· Most of the reference I see online deals with measuring DC current.· I am also wondering if the meter's needle will bounce back and forth (due to AC) or will be steady.
The controller is powered by a dedicated 15A, 110VAC line.
I guess I could always just purchase a shunted meter but I am hard headed I guess...
Anyway - if anyone here could help me select a shunt and give instruction how it is connected I would greatly appreciate it.
Thank you,
Patrick
  • dredre Posts: 106
    edited 2010-06-13 21:45
    Patrick,
    Although not analog, how about using a "Kill-a-watt" meter? It has a button for displaying amperage.
    It is very useful for other metering too [noparse][[/noparse] kwatt-hrs, etc.]
    cheers, David
  • Patrick DPatrick D Posts: 62
    edited 2010-06-13 22:34
    I considered that - but for aesthetic reasons I want the meter to be mounted on the controller's case.
  • stamptrolstamptrol Posts: 1,731
    edited 2010-06-14 12:39
    You don't mention it, but is your 0-20A meter meant for AC?
    Usually, AC ammeters were meant to be used with current transformers and the meter itself was a 5 A movement (sometimes 1 A)
    As you've found, DC ammeters use a shunt which generates 50 mV ( sometimes 100 mV) when the required current flows through the shunt. As to the resistance, its just Ohm's law. V=IR.
    In general, the two are not interchangable.
    Tom Sisk
    http://www.siskconsult.com
    edited 2010-06-14 22:07
    Well - to be honest I don't know if it is for AC or DC - it didn't say...
    Here is the meter - can you tell?
    http://www.suntekexpress.com/business-%5E_%5E-industrial/repair-%5E_%5E-tester-%5E_%5E-cleaning-tools/10007924/inventory.html
    edited 2010-06-15 02:02
    DC
    - Stephen
    edited 2010-06-15 02:04
    well - crud. Thanks for the info!
    edited 2010-06-15 02:25
    This looks like a DC meter. You can use it with AC by adding a bridge rectifier and shunt resistor as shown in the attached schematic. The value of the shunt resistor can be determined by using a low voltage source and connecting the meter in series with a high value potentiometer.
    edited 2010-06-15 02:48
    Thank you!
    about determining the shunt resistor:
    "...determined by using a low voltage source and connecting the meter in series with a high value potentiometer" - I hate to be a nuisance but could you direct me to a web site where I could get more info on this? I understand Ohms law, series and parallel circuits, etc, but not sure I know how to do what you are telling me.
    edited 2010-06-15 05:09
    There are 2 ways to approach this.
    Referring to CIRCUIT A in the attached diagram, connect the battery (1.2 - 1.5V), a 10K potentiometer (set to max resistance), and the meter as shown.
    1 - Adjust the potentiometer until the meter reads full scale and then read the voltage between points A and C. This is the full scale voltage of the meter.
    2 - Read the voltage between points A and B, remove the battery from the circuit, and measure the resistance between points A and B. The full scale current of the meter is V/R.
    3 - The shunt resistor required would be the full scale voltage of the meter (from 1) divided by 20 (from the printed meter scale).
    It may be difficult to source a shunt resistor of the required value so you can use a slightly higher value shunt resistor and a potentiometer as shown in CIRCUIT B. If you have an AC current meter you can connect it to the line and use it to calibrate CIRCUIT B.
    Thank you very much!
