interfacing tcs230 with msr1 prop
http://www.w-r-e.de/robotik/data/opt/tcs230.pdf
http://www.parallax.com/Store/Microcontrollers/PropellerDevelopmentBoards/tabid/514/CategoryID/73/List/0/SortField/0/Level/a/ProductID/584/Default.aspx
I enclosed datasheet of the actual color sensor circuit I have.
I am not quite sure how to interface the two.
The prop motor board has 3 pins, ground, signal, and power. On the color sensor from what I've seen I have 9 pins, but I can reduce the number to 5 pins for use, but that still leaves me with two pins too many.
any help/ideas? Or have I completely missed something?
EDIT:
one thing I was thinking was
vdd -> power
vss -> ground
s1&s2&out -> signal
im not sure if that would work however.
Post Edited (p00ndawg) : 6/14/2010 6:59:42 PM GMT
EDIT:
vdd -> power
vss -> ground
s1&s2&out -> signal
For those interfacing the newer daughterboard version to the MSR1, the daughterboard's Vdd and +5V pins can be tied together and supplied with +5V.
In both situations, you will need to use the MSR1's voltage translators.
Post Edited (Phil Pilgrim (PhiPi)) : 6/14/2010 7:27:16 PM GMT
Jim
