Need advice: Two servo tilt/swivel mount.
Oldbitcollector (Jeff)
I have a "device" (approx: 4"x5", weight around 5 ounces) which needs to be mounted on my bot. It has a center bolt hole in the bottom.
I need it to tip upward and side to side. (picturing two servos here)
I could use some advice on something I could build from hardware store typical materials.
(My mechanical limitations are starting to haunt me here.)
OBC
Propeller Feature Projects: PropellerPowered.com
Visit the: PROPELLERPOWERED SIG forum kindly hosted by Savage Circuits.
OBC
Don't know how much you want to spend, but I have used two of these so far, (why re-invent the wheel? Only Phil has the cool gadget for making his own [noparse]:)[/noparse] :
·http://www.servocity.com/html/spt200_pan___tilt_system.html
This one will handle up to 10oz and is a lot cheaper:
·http://www.servocity.com/html/spt100_pan___tilt_system.html
Note: Servos not included
Jim
http://www.lynxmotion.com/Category.aspx?CategoryID=61
John Abshier
I replaced the tilt mechanism with another version from servocity: http://www.servocity.com/html/ddt540_direct_drive_tilt.html . It's much easier to balance the load with this one and the tilt servo isn't straining as much.
I use this to mount a video camera (actually, one of two cameras weighing 9 oz and 16 oz (without batteries)).
The mechanisms are not that complicated, but I've found that making anything but the simplest version takes me more time than I have available to make the parts precisely enough (matching sides, etc.). For me, this was a case where I decided to throw some money at the solution.
Should work perfectly for what I have in mind!
Lynxmotion wanted to charge me $10 shipping for a $9.00 part. (blah!)
They weren't around to answer the phone today, so I'll try them next time.
Thanks guys! $25.00 well spent will save me a LOT of aggravation!
Looking forward to seeing this work!
OBC
Handed the package of candy they included in the box to the wife and daughter and heading down to the lab.
(With their blessing, it's women's day out today. [noparse]:)[/noparse]
This looks like it will fill the bill nicely! Thanks hover1
OBC
I know what you mean about keeping thing on balance, and within the cababilities of the servos. I designed a couple of Owl heads to meet the load limitations of the servos on the ServoCity SP200 Pan/Tilt. 2 Liter cup with 1.5 lb. pour foam around it..perfect, about 1.1 lbs.·Send it out to an artist to finish the facials..all of a sudden, there is is 1.25 lbs of epoxy putty on the front!·This is the second one. The first one was 2 lbs of putty on the front, the are going to learn how to sculpt out of foam!
Found a friend in the Owl's head today, Brown Recluse.·The head has·been sitting on the floor for about 3 weeks, guess it was a nice home. I have caught quite a few in the glue traps around the house, but the is the biggest and the first one I caught alive.·Being more deadly than a·Black Widow, he didn't make it into my petting zoo.
@OBC
Can we get pics or do we have to wait untill the expo?
Post Edited (hover1) : 6/13/2010 1:38:40 AM GMT
At the risk of hijacking OBC's thread -- but I assume he's just as curious -- you've got an owl wearing a pack or parachute. WT...? Enquiring Minds Want to Know!TM
Darn, I didn't know I posted the full body picture. It's a new drone that I have been working on for the military. I'm in trouble now!
Actually, it's an Owl that sits in a tree at a library. It has big eyeglasses and a little benie (got to get a propeller benie !) so it looks like a young nerdy student, (hence the backback). Pan and tilt movments on the head. 25 random mp3 files played from VMusic2 when triggered by PIR. Beak moves during the time the audio is output, but is not synched just yet. One wing flaps randomly.
This is going to be the second installation, just got to get the artists to think weight, (or lack of)!
Jim
http://cgi.ebay.com/Servo-Motor-Assembly-Support-Two-DOF-Arduino-robot-/270588005025?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item3f004d4aa1
