doubly linked lists in spin
I haven't seen this anywhere so I thought I'd give it a shot. I use doubly linked lists in C all the time. I
used ctospin to do the initial hard part. Let me know what you think. I'll submit it to obex if it's worth it.
I'm a fan of abstract data structures like this especially when it helps provide a
clean solution to something otherwise difficult like the travelling salesman problem.
One thing that stops me from trying it out is lack of the serial driver.
I just don't keep MultiCogSerialDebug.spin in my library ...
If you package the project using the File->archive feature, it will be easier to test.
Method names enqueue and dequeue are very common and have clear meanings.
I would certainly object to push/pop [noparse]:)[/noparse] Just my opinion though [noparse]:)[/noparse]
Cheers,
--Steve
Propeller Pages: Propeller JVM
I recommend adding "waitcnt" after debug.start though to give the user terminal time to open up.
Cheers,
--Steve
