Propeller Platform VGA-AV board - now available
As announced a couple of weeks ago this multi-I/O interface board for Propeller platform units is now available. PCBs arrived this afternoon and checked out perfectly, kitting has begun. Shipping this item can commence Saturday.
The bare PCB is $10, complete kit is $18 $19. In quantity 3 its $27 and $49 $52 , all prices plus Shipping and Handling. If you have a need for larger quantities contact me for pricing.
Board has:
1 - Propeller VGA - Pins 16..23 - standard VGA connector
2 - Composite Video - Pins 12..15 **
3 - Mono Sound - Pin 11 **
4 - 2 PS2 ports at 24/25 and 26/27 for mouse and keyboard - mini DIN 6
5 - small proto area with access to pins 0..10 which are not used by the I/O interfaces above.
** - Audio and Video brought out to an "A/V" connector which is a 3.5mm stereo phone jack, following the pin arrangement of the Propeller Backpack. ("edge" real estate being scarce on the Platform board, use of the A/V connector allowed me to put the whole shooting match on one board!) For small composite monitors like the ones Parallax sells or the Intec Game Boy monitors with A/V ports connection is just a male to male 3.5 mm stereo audio cable. Radio Shack has a good selection of 3.5 mm stereo to RCA cables and adapter dongles.
More pictures and ordering at
www.wulfden.org/TheShoppe/prop/index.shtml
cheers ... BBR
cheers ... brian riley, n1bq, underhill center, vermont
The Shoppe at Wulfden
www.wulfden.org/TheShoppe/prop/ - Propeller Products
www.wulfden.org/TheShoppe/k107/ - Serial LCD Display Gear
Post Edited (Brian Riley) : 6/11/2010 9:19:54 PM GMT
Board has:
cheers ... BBR
Brian sent me a prototype to play with a while back - it's a very nice board that does Composite, VGA, and audio out. Uses the standard demoboard pinouts, too.
Propeller Forums RSS Feed!
Gadget Gangster - Share your Electronic Projects
I ordered mine!!
I always have someone watching my back.
