damaged professional dev. board, repair info needed.
A while back, I was trying to use my Parallax Professional Development board to do something related to some project that concerned turning room lights on and off, but anyway, due to a lack of foresight, a couple of large valued capacitors (somewhere between 1,000 and 100.000uF each) charged at 16v ended up discharging through the Vdd and Vss connections. Big no-no.·
· After panicking a sufficient amount, I disconnected power. Once the metaphorical flames abated, I was able to determine that the pulse·generator took the brunt of the discharge, as whenever power was applied to the board, this part would heat up. (When I say heat up, I mean making my finger do this:
Squinting through a magnifying glass did not get me the part number, as the text was smudged and worn on the poor surface mount IC. Perusing the online parallax schematics of the board tells me it is a PIC12F629. This means I cannot simply order a new one from digikey.com (or other supplier), for it is not a logic chip; it is a microcontroller.
So, I present to thee these questions three:
1. Would it be risky to the other nearby parts if I used a bic cigarettte lighter to get the little SMT IC off? (Yes, soldering with the blue part of the flame is hard, but I have no hot-air tool yet, so this is what I'll have to use.)
2. How much will a replacement of just the IC cost?
3. If the cost is not excessive, what do I need to look out for when soldering the little bugger back in?
Any help or advice would be greatly appreciated.
)Squinting through a magnifying glass did not get me the part number, as the text was smudged and worn on the poor surface mount IC. Perusing the online parallax schematics of the board tells me it is a PIC12F629. This means I cannot simply order a new one from digikey.com (or other supplier), for it is not a logic chip; it is a microcontroller.
My advice would be to contact our Tech Support Dept. and see what your options are. You're focusing on the part you have determined to be damaged, but there are at least 5 other ICs on the board connected to the same supply rails that may have been damaged too and after replacing the one you know of, you could then have to address the others as well.
I have seen someone with the right equipment replace the pulse generator only to have to replace the DS1307, MAX232E and of course the regulator and its caps. Definitely check with Tech Support on this one.
Chris Savage
Parallax Engineering
I'll put away the bic lighter (it works, but it is only a 'battlefield improvisation'), desolder the pulse generator, and then see what else is damaged. I'll just have to desolder until things don't heat up, then I can go for replacement pieces....
Time to plug in the soldering iron!
Chris Savage
Don't they have some kind of a flat repair cost for
things like the PPDB and demo board?
This won't be an option if you try to solder it
with a lighter though
The original problem was he had a virus which was causing startup items not to load and therefore drivers for video and sound weren't loading, causing those items not to work. It would have been a 15 minute job (I estimated 30 minutes). Actual time to fix his machine? Two hours after scrounging screws and cables from older machines.
So to answer Holly's question...yes, for many things there is a flat fee, however, if the board is damaged deliberately that can change.
Chris Savage
As hobbyist, We don't fall by the way side until all hope is gone.Usually it works to our benefit, But sometimes it bytes us in the rear.
The Truth is out there············___$WMc%___···························· BoogerWoods, FL. USA
want speed?·want·to use the Propeller?·want to stay with BASIC___www.propbasic.com___
You can feel stupid by asking a stupid question or You can be really·stupid by not asking at all.
Chris Savage
Chris Savage
The fuse had blowed because the regulator after that fuse in the circuit was shorted to ground and burning a big hole through the board on the other side.
The price of a regulator and fuse was nothing compared to the motherboard replacement. They ended up leaving it with us not willing to fix it!
I love hacking, but only on things I've allready swallowed the loss on!
