What is the right IR receiver for BS2 and the experiments from the BoeBot manua
I was today at Radioshack, and only found "IR RECEIVED and IR DETECTOR package for 3:49 i think. But the part shown in the tutorial from Parallax has 3 pins, rather than 2. What's going on here?
What can i do with the infrared phototransistor? What's it's application?
The whole purpose of using modulated IR is to minimize the effect of ambient light. Room lights and the sun don't put out 38KHz pulses of light although some compact fluorescent bulbs did. The manufacturers of the bulbs changed the frequency to try to avoid this.
Here is some code I use with that detector and a universal remote programmed for SONY.· This code drives my bot, works some led's, and moves a ping servo back and forth.· The subs for actual direction are missing, they are not needed for this example.
