Visible or Ir
I'm not sure if this could technically be asked in the sensors forum, so here it is.
I've been toying, unsuccessfully with Ir sensors to detect walls on my bot. I understand the 38kHz or whatever modulation frequency now and the theory behind it. Implementing the thing has become a challenge.
The question isn't really about Ir though:
Ir is light that happens to be outside our visual capabilities.... OK, so what if I use high intensity red and green LED's, one color for each side???? That would work wouldn't it? The thing I'm stuck on is a receiver. Any ideas? I can't seem to find a detector. Photoresistors and diodes detect light, not specifically red or green, so that won't work..... The LED itself used as a detector might work, but it seems to be a pretty poor detector. Parallax ColorPAL is inexpensive enough, but won't work and the Color sensor is too expensive for this project.
Any ideas on a detector?
I DID just have an idea though (after writing all this).... What if I use a photodiode with a color filter!????
"puff"...... Smile, there went another one.
Lots of propeller based products in stock at affordable prices.
I think part of the reason the IR devices use 38kHz modulation is so that the IR light can be discerned from IR in the environment. If you use green light, then you can place a green optical filter over your detector but that will still allow the detector to pick up green light of that same wavelength that happens to be flickering around in your room. The modulation technique allows the detector to respond to only the light color that is being somehow "chopped". It's a form of electronic filtering. If you use green or red or whatever, then I think you will need to develop your own modulator and detector scheme to avoid stray signals from interfering with your system. But I'm not sure why you would want to go to all that trouble when IR ready-mades are cheap and already available.
Are you serious!? Um, why am I just now finding this out!? Phooey. That's good to know, I'll try it again.
Erco,
That actually makes a lot of sense. I'm getting a good modulated signal from a 555 firing the Ir LED. I'll try it again with Phil's information.
To all,
It sounds like my idea was another that would only work in theory. Oh, well. It would have been cool nonetheless.
Thank you all. Back to the circuit.
John Abshier
This is a very good thing to know and it probably should be mentioned in the educational labs that deal with these devices. Sooner or later I, myself, was destined to get burned by this situation, I'm sure of it.
Thanks Phil.
I'm modulating with a 555 and reading with the Stamp! That might just explain everything. Again, I say Phooey
Thank you Phil, you've probably saved me a lot of time.
While I'm on the Ir subject..... but totally unrelated to this discussion.... A worthy read (I thought) and very interesting. I just found this the other day, and was able to procure some 1/4" black polycarbonate [noparse]:)[/noparse] It should be VERY cool!
amasci.com/amateur/irgoggl.html
