Prop Plugs are not just for Propellers.
The Prop Plug can find a lot of uses beyond just programming and communicating with Propellers. Its compactness and logic-level I/O make it suitable for any app requiring these traits. One that I've found it useful for is an adapter cable for my FT-817 ham transceiver. It has an accessory jack that allows programming and control from a PC, such as with the Ham Radio Deluxe program.
Here's the schematic for the cable adapter I built. (The Mini DIN 8 pinout is oriented looking into the transceiver socket, not into the end of the plug.)
The 10K resistor is there to protect the FT232R in the Prop Plug from the FT-817's 5V logic levels.
Here's a photo of the completed adapter cable plugged into the radio. (The orange tag on the Prop Plug is just there to keep me from misplacing it when it's detached from the USB cable.)
_
_
- Stephen
There is no problem that can't be solved with a suitable amount of explosives!
EOD Memorial
Powered by enthusiasm
He might be referring to the spectrum display that most radios have these days - showing the signals in the band.
Leon Heller
Amateur radio callsign: G1HSM
You made my day! I prefer to look for mine - while trying to blame the dog or who ever is in the vicinity for
messing with my workspace.
Whit+
Now it's harder to lose
