BOE BOT jitter Smother move?
Hello,
I have added 2 Photoreflectors to my BOE BOT to perform line fallowing. It works but it has jittery movement do to my code and I think it could be done better but not sure how. I have used code from the TestBothPhotoresistors.bs2 and RoamingWithWhiskers.bs2 to make it work…
CIRCUIT
BOE BOT
#### THE CODE ####
' {$Stamp bs2} ' Stamp directive.
' {$PBASIC 2.5} ' PBASIC directive.
[noparse][[/noparse] Variables ]
irDetectLeft VAR Bit
irDetectRight VAR Bit
timeLeft VAR Word
timeRight VAR Word
pulseCount VAR Byte
DO
FREQOUT 8, 1, 38500
HIGH 6
HIGH 5
PAUSE 2
RCTIME 6,1,timeLeft
RCTIME 5,1,timeRight
IF (timeLeft > 1300) AND (timeRight > 1300) THEN
'SEEING ALL BLACK, BACK UP.
GOSUB Back_Up
ELSEIF timeLeft > 1300 THEN
'TURN RIGHT.. SEEING BLACK ON LEFT
GOSUB Turn_Right
ELSEIF timeRight > 1300 THEN
'TURN LEFT... SEEING BLACK ON RIGHT
GOSUB Turn_Left
ELSE
'GO FORWARD... SEEING WIGHT ON BOTH
GOSUB Forward_Pulse
ENDIF
LOOP
[noparse][[/noparse] Subroutines ]
'STOP = 760
Forward_Pulse:
PULSOUT 13,850 'LEFT
PULSOUT 12,650 'RIGHT
'PAUSE 5
RETURN
Turn_Left:
FOR pulseCount = 0 TO 3
PULSOUT 13, 850
PULSOUT 12, 760
'PAUSE 3
NEXT
RETURN
Turn_Right:
PULSOUT 13, 760
PULSOUT 12, 650
'PAUSE 3
NEXT
RETURN
Back_Up:
FOR pulseCount = 0 TO 40
PULSOUT 13, 650
PULSOUT 12, 850
'PAUSE 20
NEXT
RETURN
#### END THE CODE ####
Thanks for any help!
Shane
CIRCUIT
BOE BOT
#### THE CODE ####
timeLeft VAR Word
timeRight VAR Word
pulseCount VAR Byte
DO
FREQOUT 8, 1, 38500
HIGH 6
HIGH 5
PAUSE 2
RCTIME 6,1,timeLeft
GOSUB Back_Up
GOSUB Turn_Right
GOSUB Turn_Left
ELSE
GOSUB Forward_Pulse
ENDIF
LOOP
'STOP = 760
Forward_Pulse:
'PAUSE 5
RETURN
Turn_Left:
PULSOUT 13, 850
PULSOUT 12, 760
'PAUSE 3
NEXT
RETURN
Turn_Right:
PULSOUT 13, 760
PULSOUT 12, 650
'PAUSE 3
NEXT
RETURN
Back_Up:
PULSOUT 13, 650
PULSOUT 12, 850
'PAUSE 20
NEXT
RETURN
Shane
Eek! I just noticed that you have commented out your pauses. So what is happening is you are sending three pulses, each only a couple milliseconds apart. Your servos aren't going to be liking that.
If after changing the pause times you still do not get smooth movement it would be because RCTIME is taking too long. You could either try a smaller capacitor or read only one of the ir detectors each time through the loop. If you did that you could also change your movement subroutines so that the pulses are sent only once each time.
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
Post Edited (W9GFO) : 6/9/2010 2:22:14 AM GMT
The hole RCTIME operation seams to be a bit consuming... Oh for the love having Analog in...
Shane
' {$Stamp bs2} ' Stamp directive. ' {$PBASIC 2.5} ' PBASIC directive. ' -----[noparse][[/noparse] Variables ]---------------------------------------------------------- irDetectLeft VAR BIT irDetectRight VAR BIT timeLeft VAR WORD timeRight VAR WORD pulseCount VAR BYTE DO FREQOUT 8, 1, 38500 HIGH 6 HIGH 5 PAUSE 2 RCTIME 6,1,timeLeft RCTIME 5,1,timeRight PAUSE 15 ' adjust as needed IF (timeLeft > 1300) AND (timeRight > 1300) THEN 'SEEING ALL BLACK, BACK UP. GOSUB Back_Up ELSEIF timeLeft > 1300 THEN 'TURN RIGHT.. SEEING BLACK ON LEFT GOSUB Turn_Right ELSEIF timeRight > 1300 THEN 'TURN LEFT... SEEING BLACK ON RIGHT GOSUB Turn_Left ELSE 'GO FORWARD... SEEING WIGHT ON BOTH GOSUB Forward_Pulse ENDIF LOOP ' -----[noparse][[/noparse] Subroutines ]-------------------------------------------------------- 'STOP = 760 Forward_Pulse: PULSOUT 13,850 'LEFT PULSOUT 12,650 'RIGHT RETURN Turn_Left: PULSOUT 13, 850 PULSOUT 12, 760 RETURN Turn_Right: PULSOUT 13, 760 PULSOUT 12, 650 RETURN Back_Up: FOR pulseCount = 0 TO 40 PULSOUT 13, 650 PULSOUT 12, 850 PAUSE 18 NEXT RETURN ENDRich H
Post Edited (W9GFO) : 6/9/2010 6:53:26 PM GMT
