BS2p40 PAUSE smaller than 1 ms???
Hi Guys,
linked to my previous post on stepper motor control, I need to introduce a·PAUSE smaller than the 1ms you get with the PAUSE command to allow me to increase the motor speed.· the A4983 datasheet says it needs a minimum 1uS HIGH step signal with a minimum 1uS LOW signal.··I've put in: FOR·c=1 TO 3:·NEXT·which seems to work ok, my question is, am I right in thinking that this will introduce a delay of approximately 25uS ( (1 sec /12000 instructions per sec) * 3)???
Is there a better or·more accurate way of doing it????
thanks
Jon
thanks
Jon
Another way to get a string of pulses out fast is via the PWM command. For example,
PWM 1,41,1
PWM 1,1,41
either put out a string of 41 pulses, but the first form does it in less than 1 millisecond while the second form spreads it out over 41 times as long. The second argument (duty) should be less than 128 and the third argument (frames) can be up to 255.
The individual pulses are a little over 1 microsecond long. (A PWM frame consists of 256 time slots that can be either low or high, and duty=128 gives half and half evenly spaced).
Tracy Allen
www.emesystems.com
Here is where a scope really comes in handy. Below are a few different tests. I didn't have a BS2p40, but I used a standard BS2. The idea should still be the same however.
Tracy Allen,
Yes, the code is interpreted and it's going to take awhile to load, but you can create 'do nothing' functions using the LOOKUP or LOOKDOWN to act as a predictable hard coded timing loop, but again a SCOPE really helps to debug and determine what the timing is going to be.
Note: The times below are measuring how long the test pulse was HIGH
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 6/9/2010 8:57:45 AM GMT
The OP is asking about the BS2p40, and I surmise that the times you listed above are for the BS2 or BS2e. Right? Surmise based on the 140 µs time for LOW 0: HIGH 0. BS2p is a little over 3x faster. The LOW 0:HIGH 0 sequence takes close to 41 µs on the BS2p.
Tracy Allen
www.emesystems.com
"The OP is asking about the BS2p40, and I surmise that the times you listed above are for the BS2 or BS2e. Right?" - Yes, that is correct, I did not have a BS2p40 to check, and I indicated that in my post. I was just showing a few different methods to get a deterministic amount of timing that was smaller than the 1ms intervals.
A Scope is essential though when timing like this plays a big part of the design.
Beau Schwabe
IC Layout Engineer
