Video Output Options w/Propeller Demo Board
Hello Groovy People (you too Whit & erco),
I recently obtained a Propeller Demo Board and I've been wondering what works best for video output.
After using the large displays, the tiny, the colorful - whatever - what display option works best for you?
Scope
Scope
John Abshier
When not doing that, I use a small 7" TV from the 80's Picture is just great.
The few times I've used VGA output, it's nice, and for that I prefer a 1280 capable screen of moderate size. Right now, there are a ton of those being tossed into dumpsters. It's a great time to score older CRT gear.
In either case, I prefer the CRT for real output testing. They display lots of resolutions, and are generally more tolerant than the various LCD type displays most often seen now.
The capture is an exception, because it displays well on whatever computer display you are using, and it's very tolerant. Nice combination.
Finally, if you are doing simple graphics, moderate resolution, no fancy signals, LCD devices are great. If you are wanting to do interlaced video displays, or do dynamic graphics (where the graphics are drawn in more or less real time by the propeller), I recommend the CRT because there is no significant signal processing between you and the display. Seeing the true artifacts that result from things like interlace helps tune in a driver nicely. Some of the displays and TVs with video processors in them will actually clean things up, and or display something that is otherwise lousy, quite well. You don't find out about that until some other people go and run your stuff!!
(which is how I ended up using the older TV for a test round)
8x8 color 80 Column NTSC Text Object
Wondering how to set tile colors in the graphics_demo.spin?
It was easy to feed a TV signal to it from the Prop
and you could easily capture an avi or stills. But I
don't have access to that old PC now so I just use
VGA out to an old 13" lcd that someone didn't want
anymore.
Update: 11-Jun-2010
I purchased this 7" TV from WalMart for $67
Viore 7" Portable LCD TV, PLC7V96
I'll report if it's worthwhile when it arrives. It seems as though all the same 7" LCD panels may be manufactured from one source?
Happy Propellering,
Scope
Post Edited (Scope) : 6/11/2010 10:45:23 PM GMT
I'm connecting from the TV output on the Propeller Demo Board to the 1/8 (?) male connector on the LCD TV.
I believe I've changed all the available settings on the LCD TV without any success.
Any suggestions to help get the entire display to show up?
Thanks in advance! [noparse]:)[/noparse]
Post Edited (Scope) : 6/16/2010 5:02:03 PM GMT
Not yet . . . getting there . . . I've enjoyed playing around w/the sample TV spin code.
