VMCOG: Virtual Memory for ZiCog, Zog & more (VMCOG 0.976: PropCade,TriBlade_2,HYDRA HX512,XEDODRAM) - Page 6 — Parallax Forums
13468916
  • jazzedjazzed Posts: 11,803
    edited 2010-06-07 17:01
    Ok, please explain how to use non EXTMEM mode for testing [noparse]:)[/noparse]
    Bill Henning said...
    I am not surprised it crashed, as 0/f/b all exercise 64KB - which is too much without EXTMEM.
    Good idea, I am adding the delay.
    Propeller Pages: Propeller JVM
    edited 2010-06-07 17:16
    Happy to!
    Only reference as much memory as is allocated to the working set - so if you have 12 pages, you can only write to virtual addresses $0000-0BFF
    This could have been the cause of the corruption where you saw hub page addresses > $7C00
    jazzed said...
    www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com
    My products: Morpheus / Mem+ / PropCade / FlexMem / VMCOG / Propteus / Proteus / SerPlug
    and 6.250MHz Crystals to run Propellers at 100MHz & 5.0" OEM TFT VGA LCD modules
    Las - Large model assembler Largos - upcoming nano operating system
    edited 2010-06-07 17:31
    What is fakebox for? I don't see how it's referenced.
    Can I use it instead of hacking up vmdebug.spin for interfacing to a second COG?
    Why is mailbox defined in vmdebug.spin anyway?
    It is not used at all there except for passing the address to vmcog.start.
    Can't you just move mailbox to vmcog.spin ?
    Happy to!
    Nothing is ever easy [noparse]:)[/noparse]
    edited 2010-06-07 17:34
    fakebox is a fake mailbox, used by the silly benchmark to measure the Spin overhead for reading/writing to vmm from Spin.
    It is used by vm.readfbyte / vm.writefbyte, which execute a similar amount of code to readvbyte/writevbyte without talking to vmcog
    If you need to interface to a second cog, I suggest declaring two instances of the vm object - say vm1 and vm2.
    jazzed said...
    edited 2010-06-07 17:49
    BUG FIXED!!!!!!!!!!!!!!!!!!!
    I shaved one long too much in April, and re-used a temporary variable I should not have.
    First writes work now. I'll upload a new version shortly.
    edited 2010-06-07 17:54
    Bill,
    The point of the second cog is to run the memory interface code from that cog without adding all of that to vmcog itself. I do not want to add that code to vmcog. Having a memory driver run in a separate cog lets me redefine the driver without having to commit 10000000 different #defines in your code. I don't mind losing a cog, and I don't mind the small performance hit in my application.
    Why is mailbox defined in vmdebug.spin? It is not used at all there except for passing the address to vmcog.start. Can you move mailbox to vmcog.spin and make it 6 longs?
    Congrats finding that bug. That may have been what I was seeing in my early testing.
    Cheers.
    --Steve
    edited 2010-06-07 18:54
    Hi Steve,
    Ok - I thought you were trying to run 2 vmcog's [noparse]:)[/noparse]
    The mailbox is defined in the client applications so that more than one VMCOG can run on the same propeller. All VMCOG cares about is getting the address of a four-long mailbox in PAR on startup.
    Once BradC adds #include (if he has the time), the #ifdef forest will get thin... I plan on three files:
    vmcog-h.spin
    vmcog-init.spin
    vmcog-hardware.spin
    vmcog-h would include constants needed for the second.
    vmcog-init would have the BINIT code (that gets overwritten)
    vmcog-hardware would have BREAD and BWRITE (and a BSTART if there was one)
    That way, just rename a platforms files, no changes to VMCOG [noparse]:)[/noparse]
    Thanks re/bug... that was a nasty one.
    jazzed said...
    Bill,
    Cheers.
    --Steve
    edited 2010-06-07 19:08
    Fascinating ....
    Ok, most of that makes sense. But if you have more than one vmcog, wouldn't you need more than one mailbox?
    It seems that's an even better argument for encapsulating it all in vmcog and providing a method to get the interface pointer.
    In any event though (for more than one vmcog per propeller) it seems like there would be more than one copy of vmcog lying around with different defines per file.
    Cheers.
    --Steve
    Hi Steve,
  • heaterheater Posts: 3,370
    edited 2010-06-07 19:17
    Here is a slightly optimized version for TriBlade.
    A puzzle..
    How come this:
            mov   data, ina           'Read SRAM
            wrbyte data,ptr           'Save the byte
    Is not equivalent to this:
            wrbyte ina,ptr            'Read and save the byte
    Assuming that "data" is not further used and the timing difference does not matter?
    edited 2010-06-07 19:22
    One case:
    OBJ
       vm1: "VMCOG-PROPCADE"
       vm2: "VMCOG-TRIBLADE2"
    VAR
       long mbox1, mbox2
    PUB main
       vm1.start(@mbox1,$7E00,8)
       vm2.start(@mbox2,$6E00,8)
    In this case, yes, mbox could be defined in the vmcog.spin file
    But consider this case:
    OBJ
       vm1: "VMCOG-SPISHARED"
       vm2: "VMCOG-SPISHARED"
       cpm1: "zicog"
       cpm2: "zicog"
    VAR
       long mbox1, mbox2
    PUB main
       vm1.start(@mbox1,$7E00,16)
       vm2.start(@mbox2,$5E00,16)
       cpm1.start(@mbox1,$00000)
       cpm2.start(@mbox2,$10000)
    - assume there is a semaphore around BREAD/BWRITE so only one VMCOG can do it at once
    - assume zicog.start(@vmcog_mailbox,virtual_addr_base_for_64KB)
    then two CP/M images can happily share the same extended memory hardware, without conflict, rarely waiting for the other cpm's swapping!
    Four SPI ram's, two CP/M's, both running at close to the same speed one would run at!
    Or two ZOG's... or one ZOG / one CP/M... or...
    jazzed said...
    Fascinating ....
    Cheers.
    --Steve
    edited 2010-06-07 19:23
    Because 'ina' is only valid as a source, when used in the 'D' field you are accessing its "shadow" register.
    It really annoyed me in the past!
    heater said...
    A puzzle..
    How come this:
    edited 2010-06-07 19:29
    Bill - "Because 'ina' is only valid as a source"
    Ha! (Slaps head).
    edited 2010-06-07 19:33
    Try this Bill.
    OBJ
       cpm1: "zicog"
       cpm2: "zicog"
    PUB main
       vm1.start($7E00,16)
       cpm1.start(vm1.getbox,$00000)
       vm2.start(,$5E00,16)
       cpm2.start(vm2.getbox,$10000)
    heater said...
    Ha! (Slaps head).
    Yea, it really tweaked me when I found out about it. You could say I'm still annoyed by it [noparse]:)[/noparse]
    edited 2010-06-07 19:46
    That would work... but I still want to declare it in the client.
    Largos has pre-defined mailboxes [noparse]:)[/noparse]
    jazzed said...
    Try this Bill.
    OBJ
       cpm1: "zicog"
       cpm2: "zicog"
    PUB main
       vm1.start($7E00,16)
    edited 2010-06-07 19:51
    I am merging in jazzed's diff's right now, I will shortly upload v0.961 which will support PropCade, TriBlade_2 and XEDORAM!
    I uploaded v0.961 to the first post, it supports PropCade, TriBlade_2 and XEDORAM!
    After we test this for a couple of days with real software, I will make a version that uses a hub-based table, allowing 512KB+ of VM space.
    I am also going to be adding support for FlexMem, both CPU's on Morpheus and Morpheus+, and PLC-G.
    It would be nice to also support the Hydra memory card, as well as DracBlade and RamBlade.
    Post Edited (Bill Henning) : 6/7/2010 8:09:48 PM GMT
    edited 2010-06-07 20:07
    Thanks Bill, but I think I would rather merge the diffs myself later ... I posted those mainly for your review. I'm not happy with the the diffs as they are and I can just as easily patch the diffs as necessary until I have something that works. I still can't figure out how the pages ended up in ROM space ... any hints on that would be greatly appreciated [noparse]:)[/noparse]
    Cheers.
    --Steve
    edited 2010-06-07 20:10
    Oops! Too late.
    I am adding another "section"
    BDATA
    for interface specific data.
    That way, when there is a new revision of a specific platform (until we have includes) a simple posting here of a file with four sections can integrate easily:
    BINIT
    BREAD
    BWRITE
    BDATA
    I can also support the optional BSTART, or it can be part of BREAD or BWRITE.
    Thoughts?
    Re/ ROM space
    I can see two ways of that happening:
    1) You referred to a VM address above $FFFF, which would use an invalid TLB descriptor
    2) The TLB was corrupted
    jazzed said...
    Cheers.
    --Steve
    edited 2010-06-07 20:20
    LOL! That's what I get for eating lunch!! LOL!
    I think the vmcog.spin XEDODRAM code is mostly safe. BDATA sounds like what I need ... I look forward to details on that.
    edited 2010-06-07 20:43
    I like the BDATA idea. At the end it would straighten out that little mess I have in BSTART.
    I could quite happily move my BSTART code to the front of BREAD and BWRITE if we can spare the space (6 LONGS).
    Actually those two mods would save 2 CALLs a RET and a JMP.
    So attached is a version with a BSTARTBDATA and some more optimizations to BREAD/WRITE.
    Post Edited (heater) : 6/7/2010 9:04:48 PM GMT
    edited 2010-06-07 20:47
    Hmmm...thinks.
    That BDATA I added at the end has those pesky LONG constants you have to define for big immediates in PASM and actual variable data.
    The latter should be in VAR if you want multiple VMCogs running.
    edited 2010-06-07 20:53
    Re/ ROM space
    My working assumption is 2 and is somehow related to trying to use part of mailbox for my purpose.
    BTW: as you know DRAM is a little complicated with RAS/CAS, etc....
    One other thing that is necessary for DRAM in a one cog solution is a way to do a refresh timer.
    Today, I call the refresh in the cog interface "spinner" and use a count down timer in the refresh
    when the count down expires.
    Regardless, I'm not a big fan of this because of the spinner performance hit when enabled.
    Of course all these details are hidden away in another file and can be replaced whole-sale if necessary [noparse]:)[/noparse]
    COG Interface Spinner ...
    ' so the waitcmd loop would be something like this which of course makes a 2:1 slow down on the spinner
    waitcmd wrlong zero,pvmcmd
    wl      rdlong  vminst, pvmcmd wz ' top 23 bits = address, bottom 9 = command
            mov     vmaddr, vminst
    #ifdef XEDODRAM
            call     #mmuRefresh
    #endif
     if_z   jmp     #wl
    #ifdef XEDODRAM
    ______________
    PRI mmuRefresh
    Refresh must happen typically in less than 15 milliseconds for old DRAM.
    mmuRefresh    djnz      mmuRefCnt,#mmuRefresh_ret ' skip refresh if not time
                  ' to save some time the djnz could just as easily be djnz mmuRefCnt, #wl
                  mov       mmuRefCnt,mmuRefPer
    mmuRefresh_ret          ret
    #endif
    edited 2010-06-07 21:02
    y'all:
    Great! I will add BDATA at the end of the code, where some ifdef's currently reside...
    heater:
    I will merge in your changes in a couple of hours; re/ variables - each cog has its own local set [noparse]:)[/noparse]
    jazzed:
    That could easily be the case. Feel free to tack on extra longs to the mailbox.
    Yep, I am familiar with DRAM's - I have a bunch of different types around my lab that I intend to play with - when I have some time.
    edited 2010-06-07 21:07
    In that BDATA section I posted there is
    datax long 0
    outx long 0
    Presumably for multiple VMCOGs they should be in a VAR section.
    Scratch that. I'm getting tired here. I was in the mode of DAT that ends up in HUB but this all gets loaded to COG anyway, duhhh...
    Post Edited (heater) : 6/7/2010 9:18:18 PM GMT
    edited 2010-06-07 21:23
    jazzed, I was thinking about the refresh placement...
    It's OK to refresh dram in bursts, as long as you hit every row.
    I think it is fairly safe to assume that there will be many rdvxxxx each second, and there will be some time available right before the "jmp #waitcmd" due to the client cog having to see that cmd is now clear... so I think a good approach would be replacing "jmp #waitcmd" with "jmp #refresh"
    I'd code refresh something like:
    refresh
       mov tnow,cnt
       mov diff,tnow
       sub  diff,then wc
       mov then,tnow
       cmp diff,five_ms wc
    if_nc jmp #waitcmd
       <insert code to refresh all rows>
       jmp #waitcmd ' or fall into waitcmd
    You could also refersh say 128 rows at a time, and change the five_ms to one_ms or similar
    **OR**
    bet that reads will be done often enough, and just do a CAS-before-RAS autorefresh cycle after every read!
    Actually, assuming 1024 rows, and 15ms, you would have to do a cas-before-ras every 14.6us
    a read takes approx. 1.2us, so you would be pretty safe doing a refresh cycle every 4th read or so.
    Post Edited (Bill Henning) : 6/7/2010 9:29:34 PM GMT
    edited 2010-06-07 21:50
    I really like what you're thinking there Bill. Unfortunately there is a small problem with the approach.
    The problem with replacing jmp #waitcmd with jmp #refresh is one example from the JVM code.
    All "hardware" things are done using the JNI (Java Native Interface). This means that some code
    like the JNI delay call is all done in Spin. No Java code is required for the delay and thus, the
    vmcog spinner won't get posted.
    Yes, I'm using CAS before RAS [noparse]:)[/noparse]
    Now if we could only find a really nice way to connect that Micron 32MB SDRAM [noparse]:)[/noparse]
  • AntoineDoinelAntoineDoinel Posts: 312
    edited 2010-06-07 21:54
    Hydra+HX512 here, still something wrong it seems.
    Page replacement logic is working.
    I'm just puzzled with the readback after fill (the memory dump is ok, see screenshot below).
    Also reading a single byte to force loading a new page works, but the byte is wrong.
    VMDebug Main Menu
    1) View Page Table
    2) Flush Page Table
    3) VMREADB
    4) VMREADW
    5) VMREADL
    6) VMWRITEB
    7) VMWRITEW
    8) VMWRITEL
    9) Show VM Page
    0) Fill test pattern
    h) Heater's test
    b) Benchmark (slow, in spin)
    f) Fill memory with Word pattern
    READY>
    1
    TLB Contents:
        Acesses L D  Hub  (Raw Data) VM_ADDR
    00: $000000 - - $7600 (0000003B) $000000
    01: $000000 - - $7800 (0000003C) $000200
    02: $000000 - - $7A00 (0000003D) $000400
    03: $000000 - - $7C00 (0000003E) $000600
    VMDebug Main Menu
    1) View Page Table
    2) Flush Page Table
    [color=gray][noparse][[/noparse]...][/color]
    READY>
    f
    Filling memory...
    Reading memory...
    [color=red]0000: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 [/color]
    [color=red]0020: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 [/color]
    [color=red]0040: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 [/color]
    [color=red]0060: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 [/color]
    [color=red]0080: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 [/color]
    [color=red]00A0: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 [/color]
    [color=red]00C0: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 [/color]
    [color=red]00E0: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 [/color]
    [color=red]0100: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 [/color]
    [color=red]0120: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 [/color]
    [color=red]0140: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 [/color]
    [color=red]0160: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 [/color]
    [color=red]0180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 [/color]
    [color=red]01A0: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 [/color]
    [color=red]01C0: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 [/color]
    [color=red]01E0: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 [/color]
    [color=red]0200: B400 0202 0202 0202 0202 0202 0202 0202 0202 0202 0202 0202 0202 0202 0202 0202[/color]
    VMDebug Main Menu
    1) View Page Table
    2) Flush Page Table
    [color=#808080][noparse][[/noparse]...][/color]
    READY>
    1
    TLB Contents:
    01: $000010 - - $7600 (0000803B) $000200
    05: $000100 - D $7800 (0008023C) $000A00
    06: $000100 - D $7A00 (0008023D) $000C00
    07: $000100 - D $7C00 (0008023E) $000E00
    VMDebug Main Menu
    1) View Page Table
    2) Flush Page Table
    3) VMREADB
    READY>
    3
    Enter HEX Address: 1234
    Read Byte [color=red]$99[/color]
    VMDebug Main Menu
    1) View Page Table
    2) Flush Page Table
    READY>
    1
    TLB Contents:
    09: $000001 - - $7600 (0000083B) $001200
    VMDebug Main Menu
    1) View Page Table
    READY>
    b
    Approx. Spin overhead for Filling memory...37 ms.
    Approx. Spin overhead for Reading memory...33 ms.
    Filling memory...Spin Fill took 52 ms.
    Reading memory...Spin Read took 47 ms.
    VMDebug Main Menu
    READY>
    I need a better look, meanwhile if anyone want to try on the real hardware, as I can't test on my Proto+HX512 franken-thing (I broke the messy cable·smilewinkgrin.gif)
    I used·a 4 page working set, and only 4096 fill instead of 65536 as Gear is excruciating slow...
    P.S.: I see that you just put out a new version, this one is based on previous but the parts are easily identifiable.
    Post Edited (AntoineDoinel) : 6/7/2010 9:59:37 PM GMT
    edited 2010-06-07 22:08
    @Bill, Jazzed
    I've done a similar experiment with a Fast Page Mode SIMM: http://forums.parallax.com/showthread.php?p=869842
    I went up to promising memory tests and benchmarks, but no further (thanks to VMCog maybe that code could be recovered now...)
    For the refresh, I simply added a CBR at each command wait cycle, thus enforcing that at least one refresh cycle was made in the event of continuos page read requests.
    It only adds a slight latency to the page transfer, and in this case we're only talking of cache misses, not regular memory accesses, so I'd go with the simple and easy one.
    edited 2010-06-07 22:13
    Here is vmcog plus triblade v0.7
    Further optimization of the BREAD/BWRITE loops. Now about as tight as they will ever be.
    edited 2010-06-07 22:38
    How long is the longest JNI call, in ms?
    I would be perfectly willing to add a "VMREFRESH" command, that Spin could send to the mailbox to force a refresh...
    also, at the cost of a 200ns performance hit, it would be possible to change the spinner to incorporate a "is it time to refresh yet? / call refresh" two instruction sequence.
    Funny, I have five of those 32Mx8 TSOP-II parts in my "in box"... strange coincidence, don't you think? They arrived from Digikey a few months ago...
    jazzed said...
    edited 2010-06-07 22:42
    Welcome!
    Try the new version, I fixed a bug where the first value written to a non-present page would be corrupted. I was re-using a temp variable in one place too many [noparse]:)[/noparse]
    With a four page working set, you could just fill to 2048 and it would force a flush of all four pages.
    Looks like I need to add a "'#define HX512" to BINIT/BREAD/BWRITE/BEND in the next version... smile.gif
    AntoineDoinel said...
    I need a better look, meanwhile if anyone want to try on the real hardware, as I can't test on my Proto+HX512 franken-thing (I broke the messy cable smilewinkgrin.gif )
    I used a 4 page working set, and only 4096 fill instead of 65536 as Gear is excruciating slow...
