Cluso's RetroBlade - Preannouncement for design feedback
Cluso99
I am pre-announcing Cluso's RetroBlade for feedback in case there are improvements to be made or something I have missed.
IMHO the·2 prop solution is the best way to go, and I am unable to improve on the RamBlade design.
So, what is Cluso's RetroBlade...
I anticipate the SMT version will fit into a plastic box (hopefully Hammond translucent blue). The user will need to cut/file the connector holes out to fit. I am hoping to have the T/H version also fit into a plastic box modified by the user.
A RetroBlade can be built by using a RamBlade plugged into a Prop ProtoBoard, DemoBoard, etc, with the appropriate circuit/connections. These will be published.
For those of you with RamBlades already, you will be able to buy the RetroBlade without the RamBlade section (it may not fit into the box???).
Have I missed anything ??? Any suggestions ???
Post Edited (Cluso99) : 6/6/2010 3:18:06 AM GMT
- It is·intended to run most of the Retro Computer emulations on this forum and more
- It is intended to run any of the Prop OSes that are being developed including
- SphinxOS
- PropDos/PropCmd/etc
- FemtoBasic
- etc
- It is intended to run any of the new languages including
- Catalina C
- PropBasic
- FemtoBasic
- Forth
- etc
- plus of course Spin & Pasm
- It will be available in two PCB versions
- Thru Hole (for self assembly)
- SMT (pre-assembled)
- It is a 2 Propeller solution on 1 pcb
- 1 Prop is the same as the RamBlade which has
- 1 x Propeller
- 1 x EEPROM (with write disable jumper)
- 1 x 512KB SRAM 55nS
- 1 x microSD
- 104MHz overclocking
- 1 Prop has
- 1 x Propeller
- 1 x EEPROM
- 1 x PropPlug connector (no FTDI chip)
- Possible provision for reset circuit (transistor+R+C) to aid in using alternate PropPlug loader (maybe T/H version only?)
- 2 x USB-A or 2 x PS2 connectors (dual footprints)
- for USB/PS2 Keyboard (in PS2 mode)
- for·other USB (perhaps Bluetooth with Micah's object) or mouse
- 1 x VGA
- 1 x TV
- 1 x Stereo out (simple RC filter, no IC amp)
- 1 x 3 pin connection to onboard RamBlade (or external RamBlade)
- 2 pin for high speed serial connection >8Mbps
- 1·pin to reset RamBlade
- 1 x 8 bit expansion header
- An external regulated 5V power supply is required
- 1 x miniUSB connector is provided for connection from
- a phone, camera or iPod charger
- a USB port
- a Car Cigarette Plug to 5V USB supply
- a regulated 5V PowerPack
- Possibly 1 x optional DC input connector (T/H version only)
- On-board 3V3 regulation
- Plugable xtals
How many "extra pins" are available to interface for instance a NES controller or a parallel port ?
I didn't see any RTC in your spec ?
Would it be easier, hardware wise, to just have 1 eeprom chip that can load load the first prop, and then it would load the rest via pins 30 and 31.
On the RamBlade, would you need U2 and U3?
Doug
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com
My products: Morpheus / Mem+ / PropCade / FlexMem / VMCOG / Propteus / Proteus / SerPlug
and 6.250MHz Crystals to run Propellers at 100MHz & 5.0" OEM TFT VGA LCD modules
Las - Large model assembler Largos - upcoming nano operating system
It also makes debugging easier.
8x8 color 80 Column NTSC Text Object
Wondering how to set tile colors in the graphics_demo.spin?
* No RTC - why? Because with 2 props, you can ask the date/time on powerup and 1 cog can keep accurate time. In fact, IIRC, the fsrw pasm code has this inbuilt.
* Why 2 EEPROMs? Because the RamBlade has a special fast design which means the serial I/O cannot be on P30/31. So an extra 2 pins would be required from Prop1 to load code. The RamBlade (Prop2) does not have enough pins to load Prop1. Yes, it could be done and would save U3 & U4.
* How many I/O pins left? 8 are available. Plus, if you do not want/require TV or VGA another 3 or 8 are available. The second USB/PS2 are available (2pins) and the PropPlug pins too can be free.
* A NES controller requires 3 pins and 2 NES controllers require 4 pins.
How many think I should add an option for S-Video? It impinges on my preferred RamBlade interface pins. I wanted to keep 8 pins free for other external addons. I am thiking on making it a PMOD header (www.digilentinc.com).
@potatohead: Does the extra chroma pin have to be contiguous or can it be anywhere?
What happens is VCFG is set to either output chroma on start_pin + 1, or three. In the reference video circuit, the same resistor is used on both pins. If the audio sub carrier isn't needed, start_pin + 3 isn't part of the DAC, with just the chroma signal riding on it.
something of a standard recipe. I shall definitely order a Retroblade when available.
T o n y
