Drop in the voltage — Parallax Forums
Drop in the voltage
gablorgablor Posts: 7
edited 2010-06-03 13:23 in BASIC Stamp
I developed a PC application that sends character· through a serial connection.· I cut the serial wire and tap the DT and Common and test the voltage accross using the parallax oscilloscope.· The initial result is as shown in before_connection.jpg.· I·connected the DT wire to a 22 ohms resistror and then connected the other end of the resistor to·P5 of the parallax BOE·board. I also connected the COMM to the VSS.· I measured the two wires again at the point where they are·connected to the BOE board.· The result is as·shown in after_connection.jpg.··Can anyone explain to me why there is a voltage drop?· I am not an electrical engineer and just wanted·my·PC to control motors using the BOE board(BS2 micro controller).··Can anyone help me make this connection work?·Any suggestion?·
  • gablorgablor Posts: 7
    edited 2010-05-13 08:19
    I found the reason. When I took the measurement after connecting to the BOE board I forgot to power up. When I turn on the power it generated the right voltage.
  • JDJD Posts: 570
    edited 2010-05-13 23:32
    Gablor,
    ·Excellent. I have to say thank you for posting that you found the solution; that helps the others on the forums not look for an answer that has already been answered.
    How is the PC control coming along?
    Respectfully,
    Joshua Donelson
    www.parallax.com
    It is working now. It's a bit of a learn as you go process. After I made the connection work I found out I am getting inverted signal. After some fixing I was able to get the right bit sequence (the exact character I sent from the PC). Here's how I coded it:
    #SELECT $STAMP
    #CASE BS2, BS2E, BS2PE
    T1200 CON 813
    T2400 CON 396
    T9600 CON 84
    #CASE ...
    #ENDSELECT
    Inverted CON $4000
    Baud CON T9600 + Inverted ' to get the right order bit sequence - for
    letter VAR Byte
    SERIN SI\FC, Baud, [noparse][[/noparse]letter] ' to get the character sent by PC
    I am coding to link my HB-25 to the STAMP to operate the higher AMP motor I will use. I Will send a video later when it's running.
