Good buy on Hot Air Rework station and Multimeter
I was reading some blogs and there was a link to a
bargain I just had to pass along.
I used to buy switching pwr supplies from this place and
always got good service from them.
These cost 99.00 and you also get a really nice multimeter.
They only ship in the USA and shipping is probably about
15-20 dollars. Be sure to add the code for the free meter!
They have a wide selection of extra nozzles , parts and solder tips
available.
The adjustable holder for the hot air wand is nice!
The meter also has capacitance, temp and freq functions.
circuitspecialists.com/prod.itml/icOid/9752
www.circuitspecialists.com/prod.itml/icOid/8883
available.
The soldering iron tips look like they might be compatible with those from Weller. Can you confirm this?
But a quick email to the site will probably
get you an answer
post any answer you get here as it might be useful to others
looking for a cheap hot air station.
"Are you suggesting coconuts migrate?"
If you do, let everyone here know how it goes
These look really nice and the free meter looks great too.
I have 2 of the meters they offered as free gifts before this model.
The older meters are NICE, these look even better!
This has an LED back-light which is something I insist on in a meter.
They have other gifts to choose from but the meter is the best
of the bunch.
They have a super nice 80.00 bench pwr supply too. 0-30v
digital readouts and adjustable V and current. These people
always did have the best pwr supply deals.
If you are careful you can solder a sm prop
without even using solder paste.
And to remove a multi pin sm chip hot air is
wonderful and really beats solder wick.
Get a bunch of junk boards covered with sm parts
and practice getting the parts off and soldering them back
on.
Lardom, Surface Mount Soldering looks easy in this video.· Once they explain how it is done, I believe anyone can do it.· The hard part is just being unfamiliar with the parts needed and how to operate.· I believe you or almost anyone can do it.
Surface Mount Soldering 101
http://www.youtube.com/watch?v=3NN7UGWYmBY&feature=player_embedded
Keep in mind however, that the biggest problem with lower cost hot air rework stations is temperature stability. I have tried several units over the years in attempts to find lower cost units, but Hakko still takes the cake as far as temperature stability. Experienced rework operators who use them daily can easily see the difference between units and my current process tech (that can solder anything) will only trust her Hakko 851B for hot air rework.
For those looking to take advantage of this lower pricing for home use, I would recommend their digital version with the solder removal attachment for $199. The digital controls would more than likely have better temperature stability.
You can also try this method
Andrew Williams
WBA Consulting
My Prop projects: Reverse Geo-Cache Box, Custom Metronome, Micro Plunge Logger
@chuck - it looks like a good price. While it won't be as good as the Hakko, (and it won't look as nice after re-working) I bet it will be just fine if you're using lead solder.
You can solder a QFP with any iron (I've done it with my cheapo $30 elenco), but removing it is a pain without hot air. I've used regular hot air gun, which works for removal, but there's too much air volume (and too little temperature control) to do any re-work.
Propeller Forums RSS Feed!
Gadget Gangster - Share your Electronic Projects
Ordered one this morning! A heat gun is nice but it's time I stepped up to a re-work unit.
So, how much did they charge you for shipping?
What is your opinion of the free multimeter?
I got it really fast though, I am in LA and they are in AZ.
Meter is great, tests out good.
Soldering iron uses the same plug as my Radio Shack Digital Station. Hmmm. No must resist urge to experiment. Ain't broke don't fix!
Hot Air lifted a 64 pin conexant chip off and old modem in about 40 seconds at half throttle.
I never expected to use it for fixing a game console but this tool has proven to be helpful in that regard too.
Robert
