Can someone direct me to resources for anti-flammability
I'm new to the forums, HI.
I've googled, but I'm not sure the right terms.
I've searched here, but again maybe wrong terms
I'm looking to protect my stamp creation, from causing a fire
while in a flammable environment ... well not really flammable, just around lube oil, but still, i would like to prevent it from causing a fire in case of malfunction, or overload, etc.
Can someone point me to resources where I can read up on this.
Matt
while in a flammable environment ... well not really flammable, just around lube oil, but still, i would like to prevent it from causing a fire in case of malfunction, or overload, etc.Can someone point me to resources where I can read up on this.
Matt
http://www.ldpi-inc.com/main-site/technical/articles/class-I.htm
And the idea of this is that electrical gizmos are "sealed tight" so gases and flammable liquids can't get into them, and sparks can't get out. You see these types of enclosures around a gas station. They look quite heavy duty like this...
http://tecpro.com/store/explosion-proof-cameras/m12d-sec-ep?vmcchk=1
NEMA Enclosure types...
http://www.engineeringtoolbox.com/nema-enclosures-d_919.html
Explosion proof enclosures...
http://www.google.com/images?um=1&hl=en&tbs=isch%3A1&sa=3&q=%22explosion+proof%22+enclosures
Post Edited (bill190) : 6/1/2010 10:43:35 PM GMT
Exactly what I needed to get started.
Take a look at http://www.exforklifts.com/ex.htm
Look closely at the diagram and notice how the hot gases are dissipated. I just wanted to throw this out there so you don't go putting your device is some type of water tight enclosure thinking it will do the job. (BTW you will get sticker shock when you look at the price tag of these things).
Hope this helps.
Alex Burke
"It is not how smart you are rather, it is how you are smart." -Jon Campbell
