Hidden Electric Motor Allows Pro Cyclists to Cheat?
http://www.youtube.com/watch?v=8Nd13ARuvVE
Conspiracy theory·French/Italian video supposedly shows how a very small motor can be stealthily installed on a road bike. Goes on to show pro rider Fabian Cancellara doing incredibly effortless·accelerations in the·Roubaix-Vlaanderen bike race. Wild speculation at its finest.
No motor or battery details. Probably just a hoax, but I'll keep my Ebay eye·out for cheap·Chinese bike motor cheats. I still do lots of cycling and I gotta stay one step ahead of the faster younger guys!
I've seen many electric bikes, and they are TANKS. Many use LEAD ACID batteries.·A decent road bike is a pretty efficient machine on its own. But once you add a motor & batteries, you have to add suspension and strengthen this and that for reliability, so the weight increases and you reach the point of diminishing returns pretty quickly.
But if there is any truth to it,·that kind of energy density (small motors and batteries) would make for a small & powerful robot.
Searider
You don't need a motor. I remember those scary
videos you posted on youtube!
50kph ~= 31mph...I just don't see how that's possible with no sign of batteries. And then the added weight?
Hmmmmmm,
DJ
in the rear wheel hub. Then I'd run the conductors up to the handlebars
and use some kind of conductive wrap on the bars. Then just carry the
batteries on your person somehow and run the leads to your cycling
gloves and when you grip the bars....zoom
Batteries in the bike would make it heavy and someone would notice.
I can't imagine that they would care how much the cyclist weighed though.
Ya, erco, you should fix the stop signs - automate them so they recognize your approach, then flip 180 degrees and display "GO!"
My son got a $180 ticket for running a red light two weeks ago.
"WOAH! that wasn't supposed to happen!"
If I had to do something like that I would think that the frame tubes would make an excellent place for a stack of NiMH batteries. You could hide quite a few in there!
Robert
You would need very light batteries (lithium?). And use regenerative braking.
It hard to tell how the extra weight would effect the benefits though...
Bean
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
There are two rules in life:
· 1) Never divulge all information
If you choose not to decide, you still have made a choice. [noparse][[/noparse]RUSH - Freewill]
I know some of you have investigated the woven materials used in some batteries - carbon fiber is a woven material, eh, so . . .
Folks, I think it's time we begin rethinking outside the (pink foam) box.
- Stephen
Only our imaginations are holding us back.
That, and having to go buy more peanut butter because I'm hungry and want to make a sandwich.
The schwinn uses a purpose built frame with front suspension, 24 volt lead acid pack, variable speed twist-grip throttle and 7-speed chain wheels. Motor drives the rear wheel with separate free-wheel sprocket. All for less than $400.
After three years use, battery is still going strong and gets me back and forth to the office nearly every day. I use it for the long hill (150 meters rise over 2 km) on the way home. Lets me put the same effort in as pedalling on the level with the electric making up the difference.
Yes it weighs more than a road bike, but you don't need to walk it up a hill, you don't get drenched in sweat on the way, and on the level the extra weight doesn't matter. Best of all, its gets you past that urge to wear those padded-Smile bike pants!
Cheers,
Tom Sisk
http://www.siskconsult.com
Lycra is a privilege not a right LOL [noparse]:)[/noparse]
Peter KG6LSE
"Carpe Ducktum" "seize the tape!!"
peterthethinker.com/tesla/Venom/Venom.html
Never underestimate the bandwidth of a station wagon full of tapes hurtling down the highway. —Tanenbaum, Andrew S.
LOL
I did get it up over 60km/hour in a 50km zone so I can beleive there cliam of doing 50km/h. I am sure you would have to be doing some pretty hard pedaling though with such a small motor.
as for cheating not a chance. the motor on the schwinn is very load and distinct and from the video this motor makes the same sound. People would notice the sound even if you could successfully hide the bateries.
I like the hidden motor aproach though. would stop people looking at your bike and would reduce risk of theft.
Lots of propeller based products in stock at affordable prices.
Consider 1kg of these tiny batteries. You could hide them in the frame and in all sorts of places - they are very tiny. Say you wanted an extra 100 watts - the same power as electric scooters or maybe the same as someone cruising on a bike. 180mAh lipo 3V =(I think) 0.54 watts for 1 hour. Take 150 of these which will weigh 1.05kg, and will deliver 81 watts for 1 hour. Or 972 watts for 5 minutes (which is well within the specs of the battery). The motor might add a little more weight, but motors from electric helicopters are amazingly light. Electric flight scales up too, so power for weight if something can hover for 5 minutes it will do a lot more along a road.
I wonder if anyone has built an electric bike with a real focus on weight?
