Good Breadboard gauge wire
I went to radioshack (to see if the RFID reader was still on the cheap) and bought some solid core hookup wire that is 22-gauge. I was wondering is that what is right for a breadboard? what is the gauge that parallax uses for their precut 3" strips? I would experiment but the wire was a hefty price and i wan't to be able to take it back if i have to.
"WOAH! that wasn't supposed to happen!"
I don't know what Parallax provides but I've used 22 gauge wire for breadboards for years. Just make sure what you bought is SOLID wire and not stranded.
If you buy online or through catalogs, you can probably get that wire for a cheaper price but if that is all you are buying then you aren't going to save a lot of money because you are going to pay shipping.
Some of the breadboard wires advertised on some of these cheaper sites aren't sturdy and while I haven't cut one open to see what it is yet, I would probably go with a good guage wire unless it is for convenience. As long as you have connectivity then I don't have a problem.
I found another breadboard wire kit from an Elenco supplier but the breadboard wires are probably steel so they aren't copper.
off the rolls and use that. Not sure what gauge it is...
But it's CHEAP and 8 color schemes.
I do have some of the better quality pre-made stranded cables with pins soldered or crimped on the ends. The flexibility can be convenient sometimes. You can get pretty good quality ones fairly cheap. I've also used really cheap ones that are more problematic than helpful - the pins tend to be too small and they don't stay in the breadboard (especially if you stick headers into your breadboards like I do (and just about everyone else does)).
·http://cgi.ebay.com/Qty-210-Solderless-Breadboard-Jumper-Cable-Wires-Kit-/350299182556?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item518f7555dc
If you can get them if they soldered, that's better than crimped.
Now Holly is going to go off and find them 50% cheaper, and better, and have a free O'Scope with the offer.
(Bows to our ebay queen).
Jim
A similar set of 70 pieces pinned rubber jumper wires of various lengths are available from SOLARBOTICS.COM for .... you guessed it, half the above ebay price, at $6.00. Item 21035 under the "ADVANCED" heading.
They work great, and have sure cleaned up MY patch boards.
Sorry, no free O'Scope!
Cheers,
Peter (pjv)
(now parted from me..I need to order more)
The boards came with a generous supply of jumpers
with nice tinned ends. There seem to be more people
selling them now. Here are 3 links
cgi.ebay.com/2860-Tiepoint-Solderless-Breadboard-Includes-Jumpwires-/390203565360?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item5ad9f1e530#ht_2091wt_920
cgi.ebay.com/2-860-Tiepoint-Solderless-Breadboard-Includes-Jumpwires-/220610804476?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item335d6dbafc#ht_2032wt_1148
And this one---same image as the first link... I believe this is the person I ordered from before. Not certain though.
cgi.ebay.com/2-860-Tiepoint-Solderless-Breadboard-Includes-Jumpwires-/150444692995?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item230733d603#ht_1197wt_912
See the two power connectors at the top of these boards.
I put a 5v regulator beneath the right one and connected
its output to a 3.3v one beneath the one on the left. Then I
drilled a hole in the green plastic board at top middle and
used a plug in pwr supply to feed the board 9v or so. I tied
the pwr supply feed wire through the hole for strength.
20' of cat5 will give you a little over 80' of usable wires in 8 different colors. Just spend a little time to unwind the wires and straiten them out with your fingers.
Lots of propeller based products in stock at affordable prices.
But the device breadboard connectors on the Parallax propeller professional development board has slightly larger openings, and the phone wires don't grip well in them. The Radio Shack 22 gauge wires work well there, but they are much stiffer (and more expensive) than the phone wire.
http://www.pololu.com/catalog/category/71
I find the pins on these are a little larger than the cheap ones I've got and they fit better in headers. I threw something together quickly for UPEC using the cheaper wires (4 or 5 of them) and ended up replacing them with ones from Pololu in the hotel the night before because the cheap ones kept falling out.
Pololu sells them with M-M, M-F, or F-F ends and you can buy housings to group them together. The housings and F-F could replace the ones I've crimped/soldered myself for years (using housings and connectors from Jameco).
If you don't want to use the housings and just want a single wire connections, you can use heat shrink tubing around the crimps at either end to provide some isolation.
While I still make my own cables, I've also bought a nice supply of these from Pololu. When you want a quick cable and don't want to bother with the cutting, stripping, crimping, and soldering (I always do both on my own cables) they are nice to have around. I have numerous lengths with all end combinations.
