SpinStamp ? — Parallax Forums
SpinStamp ?
jazzedjazzed Posts: 11,803
edited 2010-06-03 13:32 in Propeller 1
Any good reason for Spin Stamp to not show up in the common Propeller store pages?
Propeller Pages: Propeller JVM
  • kf4ixmkf4ixm Posts: 529
    edited 2010-06-01 20:30
    Spin Stamp? never heard of such a beast or did i miss something yes i did!?
    EDIT:
    Well ill be _____. never heard of this before and i thought id seen everything parallax has to offer!
    http://www.parallax.com/Store/Microcontrollers/PropellerTools/tabid/143/ProductID/448/List/1/Default.aspx?SortField=ProductName,ProductName
    I'm just 7*1027 atoms floating through time and space in close formation. -KF4IXM
    Post Edited (kf4ixm) : 6/1/2010 8:35:40 PM GMT
  • hover1hover1 Posts: 1,929
    edited 2010-06-01 20:35
    It shows up at:
    Store > Microcontrollers > All Microcontrollers Page 7
    and
    Store > Microcontrollers > Propeller Tools
    I agree it should show up on the the same page as the Prop Stick USB:
    Store > Microcontrollers > Propeller Chips
    Jim
  • jazzedjazzed Posts: 11,803
    edited 2010-06-01 21:50
    hover1 said...
    It shows up at ...
    Hey! You're right! I never dreamed to look in the "Tools" section though [noparse]:)[/noparse]
    It's a shame that 9 or so pins get wasted in that form-factor.
    edited 2010-06-01 23:00
    I believe it should also show up as a product for the BOE-BOT, (as an alternative with red warnings about the 3.3 vs 5.0 volt signal, which they already do but not in red), given that Mike Green has written BOE-Bot Basic for it and Terry Hitt (Bean) has put out PropBot examples for the Propeller PBasic Compiler.
    In my opinion, there hasn't been much marketing for this module. I have two, and now the I have another complete BOE-Bot, it's going to be Propeller powered. I'm going to try and do the whole project with 12Blocks. I think it's a pefect combination.
    Jim
  • wjsteelewjsteele Posts: 697
    edited 2010-06-02 00:18
    You know what... you could buy two of these for a little more than the price of the PropStick... and get more I/O and double the RAM and Cogs! wink.gif In quantites of Twenty... two SpinStamps are one cent less than one PropStick!
    Bill
  • Tony B.Tony B. Posts: 356
    edited 2010-06-02 23:53
    Ive been using the Spin Stamp in a BOE on what I call my Development Board http://forums.parallax.com/forums/default.aspx?f=5&m=415529 It has worked flawlessly and makes it very easy to test Propeller code on. I also have a BOE-BOT that is propeller powered. I am writing code in PropBASIC for it. Hope to help BS2er move to the Propeller chip.
    Tony
  • RaymanRayman Posts: 15,450
    edited 2010-06-03 13:05
    I have a Spin Stamp that I decided was useless until I got my BoeBot. Then, I gave away the BS2 it came with and plugged in the Spin Stamp and had some fun.
    But then, I found out that the Protoboard is the exact same size as the BoeBot board. So now, I think the Spin Stamp is useless again [noparse]:)[/noparse]
    My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
    My Prop Products:· http://www.rayslogic.com/Propeller/Products/Products.htm
    But then you·find·Bill's Morpheus board will also fit and make the Proto Board useless.
    Rayman said...
    800 x 600 - 165K
