configuring XBEE with prop
I am trying to change the channel of an XBEE module using serial transmissions. I know this is possible but it does not seem to be entering into config mode with my code (it just transmits the plus signs to the receiver).
SERRF.STR(string("+++", 13)) '+++ puts the XBEE into config mode but it does not.
SERRF.STR(string("CH", $C, 13, "ACTN", 13)) 'These commands should change the channel.
I think there is a xbee object on obex why not check that for what happens with +++
http://obex.parallax.com/objects/146/
As it encapsulates the delay around the "+++".
Example code for starting: ' ************************** OBJ XB : "XBee_Object" Pub Start XB.start(7,6,0,9600) ' XBee Comms - RX,TX, Mode, Baud XB.AT_Init ' Initialize for fast AT command use - 5 second delay to perform XB.AT_ConfigVal(string("ATMY"),$5) ' Set MY address to 5 . .Note you need to send just "+++" with the proper guard times before & after it. Your sample is sending +++ plus a carriage return.
Hope this helps
Jay
.Steve
