Assigning an Auxio pin as a constant
Hi Team,
It's probably something simple that I overlooked, but I'd like to be able to use a constant to refer to an Auxilliary pin on the p40.
I added a second Ds1867 digital pot to a circuit that has·all the main·IO pins used already and would like to have the second DS1867 configured like the first:
The first one is configured:····Rst1··· ·CON·· 1
I'd like the second one:······· ·Rst2···· CON·· Aux10
The subroutine for·the first·DS1867 just uses: ·HIGH Rst1·· /· LOW Rst1
I'd like to be able to use: ·HIGH Rst2 ·/ ·LOW Rst2··· for the subroutine for the second, (and any additional) DS1867 as well
As it is, I can work around the issue with:· ·AUXIO : HIGH 10 :MAINIO /··AUXIO :·LOW 10 :MAINIO·· for the second 1867
but it would be nice, especially for future use, to know how to set an Aux pin as a constant.
Thanks in advance,
Darlene
Thanks in advance,
Darlene
As far as your program is concerned, there are only 16 I/O pins and there's no automatic way to switch between the two sets of 16.
