Method not working how expected
I have this method
When I input a value in the PST the ESC doesnt respond, but the number comes up on the PST. Attached is the complete code.
Pri ControlESC | value
Debug.tx(16)
Debug.Str(String(13, "Calibrating Mamba25 ESC complete!"))
repeat
Debug.Str(String(13,"Enter a ESC value 1810 = Full throttle, 1479 = Nuetral/Full Brake, 1048 = Full reverse: "))
value := Debug.getDec
servo.set(escPin, value)
Debug.Str(String("You Entered: "))
Debug.Dec(value)
Are you sure that it expects the pin number? Maybe it expects the bitmask.
Or ... are you sure that you use the right pin number? The numbers go from 0 to 31 and not from 1 to 32 as one might think. So, the last port-pin on the left side of a DIP-propeller is 15.
Don't you have to initialize the servo-object?
