Propscope hardware crashing
I've been chasing an obscure bug which I can't seem to reproduce on other hardware.
This program here will pop out messages to the serial terminal at 38000 baud. I never get more than about 10 seconds in before the Scope crashes.
The bit that is causing the crash is clearing dira while ctrb is still running at full tilt toggling the CLK net. I can't reproduce it on any other combination of pins, and if I disable the counter first (clear ctrb) then it does not happen.
It appears that this is the only way I can reproduce it.
pin 26&27 outputs
pin 27 high
counter toggling pin 26 faster than 6MHz
Now clear dira and it will crash hard but only intermittently.
The code I posted above is guaranteed to crash on my PropScope within 10 seconds.
"Are you suggesting coconuts migrate?"
CON
_clkmode = xtal1 + pll16x
_xinfreq = 6_250_000
OBJ
Term : "FullDuplexSerial"
PUB Start | X, Y
X~
Term.Start(31,30,0,38400)
Y := cognew(@fred, 0)
repeat
term.str(String("survived "))
term.dec(X++)
term.str(string(" loops",13))
waitcnt(cnt+clkfreq)
DAT
org 0
fred
mov da, #$40
shl da, #24
mov frqb, da ' Set output freq
mov ctrb, ctrb_mode ' Enable counter
mov dira, ctrb_mask ' Enable outputs
mov outa, pin ' set pin 27 high
mov da, cnt
add da, frq
waitcnt da, frq ' wait a second
mov dira, #0 ' Here is where it will crash
waitcnt da, frq ' If it didn't crash this time, go around until it does.
jmp #fred
ctrb_mode long %00101 << 26 + 26
ctrb_mask long 1<<26 | 1<<27
frq long 80_000_000
pin long 1<<27
da res 1
pin 26&27 outputs
pin 27 high
I've been out of town all week, so I wasn't able to look at this until now. I've tried running the code multiple times on my PropScope, and it works fine every time, but it does occasionally freeze on a coworker's PropScope. We are closing early today, so I don't have much time to look at it, but I'll check it out more in depth when we return on Tuesday.
— David Carrier
Parallax Inc.
No worries. I've worked around it by disabling ctrb before I zero dira. I'm just glad you guys can reproduce it (even if it's intermittent compared to mine). I'm baffled.
On my scope it will crash within 10 seconds, _every_ time.
I'll be interested to hear if you manage to figure out what's causing it.
Using your code, I ran the PropScope for 6 hours with no lockups. I reloaded 6 times at 1 hour intervals with no lockups.
The only manufacturing code is what was on the outside of the box "23225". I think I was the first or second order of this product. It's probably all the same manufacturing run.
Jim
I'm baffled myself, but the thing nagging me is... the PropScope is running a Propeller outside of the specifications on the datasheet. Is it some very strange artifact that only appears on randomly unlucky chips (like mine?). I certainly can't repeat the behaviour on any of my other Propellers which run at 80Mhz..
And kept the counter pin toggle rate the same with
mov da, #$80and it still locks up reproducibly in under 10 seconds.. so it's not overclocking that's causing it.
Tried thermal variations (both inside and outside the metal tin)
16 Deg C / 25 Deg C / 50 Deg C / 70 Deg C.. no change
Tried with and without signal sources, with and without the -2V supply switched on...
Directly connected to the USB port on my Mac Mini and via an externally powered 7 port USB hub.
The only difference I've seen is with the timer set to $40_00_00_00, on pllx16 it locks up in ~5 seconds, and with pllx8 it can take up to 8. Set the timer to $80_00_00_00 at pllx8 and it's back to ~5 seconds.
DAT org 0 fred mov da, #$40 shl da, #24 mov frqb, da ' Set output freq mov ctrb, ctrb_mode ' Enable counter mov dira, ctrb_mask ' Enable outputs mov outa, pin ' set pin 27 high mov da, cnt add da, frq waitcnt da, frq1 ' wait a second (##) mov dira, #0 ' Here is where it will crash waitcnt da, frq ' If it didn't crash this time, go around until it does. jmp #fred ctrb_mode long %00101 << 26 + 26 ctrb_mask long 1<<26 | 1<<27 frq long 80_000_000 frq1 long 80_000_003 ' (##) pin long 1<<27 da res 1The original code wasn't sync'd between the generated clock and switching off dira. With the modified delay the switch off happens at a specific point which I believe should be safe (as opposed to the one happening after 5 sec with the original setup). Thanks.
That's no red herring. Making that change stops it crashing entirely.
80_00_00_01 & 80_00_00_02 make it crash faster.
Now the question is.. why ?
CON { | mov dira, #0 | | S D e R | --+ +----+ +----+ +----+ +----+ | | | | | | | | | +----+ +----+ +----+ +----+ +-- --------+ +---------+ high 26 | | +------ floating +-------------------+ low --------------------------------------+ high 27 +------ floating low }i.e. the low cycle for the ctrb wave is still intact, the high cycle is only half completed when it gets cut off due to dira clearance. The data sheet for the analog circuit states a minimum of 5ns but that's only in a specific mode. One could speculate that this mutilated clock somehow affects this circuit which in turn would affect the prop. If it's just a simple reset one would assume that whatever is in EEPROM would run again (if it is a reset issue). Are you running from RAM only? I can't think of a reason that code like this would affect the prop on its own (after all, it's only two outputs which are being switched off).
FWIW, the 80_000_003 syncs the clock so the cut off happens at 50% low cycle.
Post Edited (kuroneko) : 5/30/2010 9:14:09 AM GMT
I put a test program into the prop to report if it has been reset. Yes, when it occurs the prop is being reset.
Thanks for the explanation. I get it, but I still don't understand *why* it's a problem.
I'm pretty sure it's not. For the PLL to be enabled the MODE line needs to be pulled to an odd intermediate level using pull-up and pull-down resistors.
Interesting theory. I might have to dig out the DSO and see if I can find something peculiar happening.
I note on the schematic, all the decoupling caps around the prop are 1.0uf.
I'm having problems reproducing it again. The PropScope that I could occasionally reproduce the problem on is now always behaving properly. When you say that the program crashes on your PropScope every time, does that involve power cycling it, or can you just press 'F10' and have it crash every time? Also, if you load it to the EEPROM does it crash just as readily?
Thank you,
David Carrier
Nope.
Every time, like clockwork. I can go from having it running nicely sampling to the PC with working firmware, and load the test program directly to crash it.
Yep.
If I use Kuroneko's mod to the test program and change the 80_00_00_03 to 80_00_00_01 it will crash faster (usually within 3 seconds).
80000000: critical switch-off after ~5sec phsb sequence: $C0.$00.[u]$40[/u].$80 80000001: critical switch-off after ~3sec $C0.[u]$40[/u].$C0.[u]$40[/u] 80000002: critical switch-off after ~5sec $C0.$80.[u]$40[/u].$00 80000003: stable $C0.$C0.$C0.$C0 ~1s ~3s ~5s ~7sPost Edited (kuroneko) : 6/2/2010 6:01:00 AM GMT
