Christmas gift idea for the true geek! TI ez430 development platform in a watch - Page 2 — Parallax Forums
2»
  • logan996logan996 Posts: 281
    edited 2010-05-25 21:52
    2 questions, does it have cogs? and what is the wireless for? could you listen to radio? or is it just like parallax's 433Mhz transivers? and could you even use this as a stepcounter? to be simple
    "WOAH! that wasn't supposed to happen!"
  • LeonLeon Posts: 7,620
    edited 2010-05-25 22:04
    It uses an MSP430 chip, not a Propeller.
    It transmits data to a PC equipped with a similar chip and USB interface, and can receive data from the PC, using the 868 MHz ISM band in Europe. It has an accelerometer, and could be used as a step counter if it was kept in a trouser pocket, with suitable software. ADI has an app note on a pedometer design using an accelerometer attached to a thigh.
    Leon Heller
    Amateur radio callsign: G1HSM
    Post Edited (Leon) : 5/25/2010 10:16:16 PM GMT
    edited 2010-05-26 23:16
    I knew it wasn't a prop i was just curious though if it had other processers in it, sorry i should have said processors instead of cogs oops lol
    edited 2010-05-27 05:27
    parallax Needs to sell a BS2 or prop watch . I know I would love to tinker with a Open watch with IR IO's and various sensors ( acccel , pressure , temp , compass, ect) built in .
    Peter KG6LSE
    "Carpe Ducktum" "seize the tape!!"
    peterthethinker.com/tesla/Venom/Venom.html
    Never underestimate the bandwidth of a station wagon full of tapes hurtling down the highway. —Tanenbaum, Andrew S.
    LOL
    edited 2010-05-27 05:53
    They'd use too much power, devices like the MSP430 or the new XLP PICs are much more suitable.
    Leon Heller
    edited 2010-05-27 07:17
    I have ordered the ez430 dongle to play with.
    I was thinking of using a 430 chip in a little project of mine
    but have decided a 5v part from microchip is a better choice
    since it is just as cheap in 1kb flash version and saves the cost
    of a 3.3 regulator. I can't believe I will have to set up to work
    with the PIC chips again. They were the first chips I ever played
    with, only a few years ago but it seems like ancient history now.
    I don't think I packed my old PIC programmer though, dang.
    If I remember correctly it was called the diy150 kit or something
    like that. I could get a cheap serial port programmer but I only
    have my laptops here and no serial just USB.
    edited 2010-05-27 12:27
    Get a PICkit 2 (if you can find one) or the newer PICkit 3; they are quite cheap and you get debugging as well as programming. I have a PK2, but I mostly use the much more expensive ICD 3.
    Leon Heller
  • edited 2010-05-27 12:31
    Brad posted some tutorials on www.bradsprojects.com on how to use the Pikit 2 and he has settled on only two chips.· He is rebuilding his site so it is a matter of time before all of the tutorials are up.· He has reposted tutorial 4 of 7.
